Re: 727 ?
[Re: Cab_Burge]
#1594731
03/18/14 09:20 AM
03/18/14 09:20 AM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
The problem with adjusting the throttle pressure like that is that it will also lower the pressure holding the clutches/bands. While you might be able to get away with it in a low power application like this, it's not the preferred method. What is strange to me though, is that you said that if you manually shift from 1st to 2nd that it will make the shift at 5500? That is surprising to me because the governor should still be controlling the 1/2 shift even when the selector is in 2nd gear. (for example, if you put the car in 2nd on the shifter, drive normally and it will still make the 1/2 shift.) Are you certain that the shift was as high as you think it was? You could also try lowering the line pressure slightly to see if that helps. http://www.moparmusclemagazine.com/techa...lvesprings.htmlScott
Re: 727 ?
[Re: dizuster]
#1594732
03/18/14 12:09 PM
03/18/14 12:09 PM
Posts: 1,608 Rudolph, Ohio
moparguy7074
Rudolph, Ohio
If you look at his post, it says that the rpms went well past 5500 when he manually shifted also.
Re: 727 ?
[Re: Cab_Burge]
#1594733
03/18/14 02:46 PM
03/18/14 02:46 PM
Posts: 25,967 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Cab's right, it's a throttle pressure issue. Shorten the TP linkage a little at a time until it upshifts without lifting the throttle.
