Re: 99 Ram trans slipping
[Re: 71yelladustr]
#1594392
03/17/14 04:57 PM
03/17/14 04:57 PM
Posts: 75,095 A Banana Republic near you.
JohnRR
Try adjusting the kickdown band first.
^^^ this , 1- 2 shift is the band grabbing the front drum and stopping it , if it's slipping it's because the band is not holding well till pressure builds .
[Re: moparmikethree]
#1594395
03/18/14 06:31 PM
03/18/14 06:31 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Just recently my 99 Ram started to slip between the 1 to 2 shift. Fluid is not burnt, and the rest of the trans is working well. What is causing this could it need a band adjustment and a filter change. Or is it on its way out. truck has 120,000 miles. Not beaten at all.
You might get lucky my 1999 Ram 1500 4X4 started slipping on the 1-2 shift, did a band adj and filter change, but the torque converter decided to head south shortly after at 166,000 mi, Oh well, 3rd Ram, 3rd tranny...
