904 low gearsets #1594359
03/17/14 03:29 PM
03/17/14 03:29 PM
Phoenix - surface of the sun
nomore65BelvJim Offline OP
I've got several mid-late 70's 904's.
I'd like to know if there is a way to find out if any of them have the low gearsets without having to tear them down.
Does the pan rail # stamping give that kind of information?
Any other way to tell short of disassembly?
Thanks!
Here's one:
Re: 904 low gearsets [Re: nomore65BelvJim] #1594360
03/17/14 03:38 PM
03/17/14 03:38 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The low gearset didn't arrive until '80, the one pictured is a '71.
Re: 904 low gearsets [Re: John_Kunkel] #1594361
03/17/14 03:52 PM
03/17/14 03:52 PM
Thanks for the info John.
Odd on the date though, I pulled that trans out of a 79 Volare.
Re: 904 low gearsets [Re: John_Kunkel] #1594362
03/17/14 05:01 PM
03/17/14 05:01 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Is there any way that the
low gear planetary out of a 904
could be used to replace the
planetary gears in a 46RH overdrive unit?
As i understand it,
to create the
0.69 ratio overdrive unit
in the 518/46RH/46RE
Chrysler engineers re-used the
1.45 ratio planetary gears out of a 727
1 divided by 1.45 equals 0.69
a low planetary set of 1.54 would create a
1/1.54 equals 0.65 overdrive ratio
Re: 904 low gearsets [Re: nomore65BelvJim] #1594363
03/17/14 06:47 PM
03/17/14 06:47 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Just means the Volare owner decided to replace his failed lockup 904 with an earlier non-lockup version... And it could have the low gearset installed if he wanted performance...
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 904 low gearsets [Re: nomore65BelvJim] #1594364
03/17/14 06:54 PM
03/17/14 06:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
My bad, I read the wrong number...build date is Feb 6, 1979
Re: 904 low gearsets [Re: 360view] #1594365
03/17/14 06:55 PM
03/17/14 06:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
No, way different in size.
Re: 904 low gearsets [Re: John_Kunkel] #1594366
03/18/14 12:21 AM
03/18/14 12:21 AM
So, if it was an 80 or newer, would there be any way to tell by the numbers?
I do drag home an 80's car occasionaly
Re: 904 low gearsets [Re: nomore65BelvJim] #1594367
03/18/14 03:31 PM
03/18/14 03:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
From what I understand, '80 and '81 were "maybe" but by '82 all transmissions in the 904 family had the low gearset.
