Known good B-body hood bracing donor for '70 Charger? *DELETED* #1593951
03/16/14 06:20 PM
03/16/14 06:20 PM
808CUDA Offline OP
808CUDA  Offline OP
Post deleted by 808CUDA
Re: Known good B-body hood bracing donor for '70 Charger? [Re: 808CUDA] #1593952
03/16/14 06:27 PM
03/16/14 06:27 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
humm the front will be hard, the rear is probably the same as any 68-70 b-body. You'd probably be better off finding a solid unit or maybe just pick up a fiberglass piece. You are going to spend a lot of time drill spot welds, then cutting welding the support back in.
Coming soon!!!!
Re: Known good B-body hood bracing donor for '70 Charger? [Re: 808CUDA] #1593953
03/16/14 09:58 PM
03/16/14 09:58 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Gil , only a charger hood underbrace is going to work and probably only a 1970 because the hood is different than a 68/69
Re: Known good B-body hood bracing donor for '70 Charger? [Re: Mr.Yuck] #1593954
03/16/14 09:59 PM
03/16/14 09:59 PM
808CUDA Offline OP
808CUDA  Offline OP
Thanks for the input. I figure as much but I'm certain a B body guru knows the differences in the bracing or have across this.
Time and labor I have. Living on an island in the middle of the Pacific will make you appreciate what you have
Re: Known good B-body hood bracing donor for '70 Charger? [Re: JohnRR] #1593955
03/16/14 10:02 PM
03/16/14 10:02 PM
808CUDA Offline OP
808CUDA  Offline OP
Thanks John. Yep, I figured as much since AMD only offers the earlier hood. Just looking at alternatives rather than hand fabbing all of the structure or scrappin' a hood otherwise that is clean.
Re: Known good B-body hood bracing donor for '70 Charger? [Re: 808CUDA] #1593956
03/16/14 11:32 PM
03/16/14 11:32 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
how bad is it? I'm guessing a 70 hood would be what $300???
Re: Known good B-body hood bracing donor for '70 Charger? [Re: Mr.Yuck] #1593957
03/17/14 02:44 AM
03/17/14 02:44 AM
808CUDA Offline OP
808CUDA  Offline OP
So far only one hood I've found for $400 has a single rust hole underneath (questionable) and a corner needs repair. Shipping to Hawaii and getting it crated I'm certain will be about $700+. If I go this route id rather purchase a pristine hood.
And again, I'd like to save a hood if possible.
