Tire and Rim Question #1593805
03/16/14 12:40 PM
03/16/14 12:40 PM
massachusetts
70Runner440+6 Offline OP
massachusetts
Would a 275 or 255/60/15 tire be too wide for a 15x6 rim? thanks
Re: Tire and Rim Question [Re: 70Runner440+6] #1593806
03/16/14 12:44 PM
03/16/14 12:44 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
255 might work but a 275 will "ballon" and you'll wear down the center.
Coming soon!!!!
Re: Tire and Rim Question [Re: 70Runner440+6] #1593807
03/16/14 02:11 PM
03/16/14 02:11 PM
I believe so (too wide of tire). The 275 is almost 11 inches (10.8) of section width which would surely be too much for those rims. As said it'd wear excessively in the tread center from the crowning & you'd lose effective tread contact to the pavement. Not sure on this but iirc you want the tread width (which is less than the section width) to be close to the rim width
Re: Tire and Rim Question [Re: RapidRobert] #1593808
03/16/14 03:14 PM
03/16/14 03:14 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
I agree with RapidRobert, those tires are too wide. BFG says for a 255/60 the wheel width should be 7"-9" and for 275/60 7.5"-9.5". The chart below shows a 225 being the largest 60 series for a 6" wheel.
http://www.bfgoodrichtires.ca/tire-selector/name/radial-t-a-tires#techspecs
Re: Tire and Rim Question [Re: moparfan53] #1593809
03/16/14 05:31 PM
03/16/14 05:31 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I run a 255 on a 7" rim. It's okay, but I don't think I'd want to go to a 6". Could it be done?.... Sure. SHOULD it be done?.... No.
Re: Tire and Rim Question [Re: StealthWedge67] #1593810
03/21/14 12:50 PM
03/21/14 12:50 PM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
I like that , exactly what I tell people.
255-60-15 at least a 7 inch rim
275-60-15 at least an 8 inch rim.
Frank
