Page 2 of 3 1 2 3
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593587
03/16/14 11:27 AM
03/16/14 11:27 AM
West Palm Beach, Florida
Copper Dart Offline OP
Yes, it does help.
More pictures for those of us that don't like reading
On to the transmission, driveshaft (from a '67 Coronet 318 727) install and linkage
Edit: We used the trans crossmember from the '67 Satellite 904, just turned the mount around.Edit
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593588
03/16/14 11:31 AM
03/16/14 11:31 AM
No exhaust to install, I will have that done at a shop.
Back up top to finish the install.
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593589
03/16/14 11:33 AM
03/16/14 11:33 AM
I want to hear it run before I give up for the night
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593590
03/16/14 11:37 AM
03/16/14 11:37 AM
Its alive! burning fuel and making alot of noise for the neighbors
I was able to use the radiator and shroud from the '68 Newport with just a little modification to the mounting. The 318 904 transmission cooler lines worked as well with the 727.
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593591
03/16/14 11:47 AM
03/16/14 11:47 AM
I had to clean out the corrosion inside the carburetor caused by Ethanol in the fuel and I still need to strip the valve covers and paint. Should finish today.
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593592
03/16/14 01:11 PM
03/16/14 01:11 PM
west palm beach, florida
modelmakerinc Offline
I am jealous, The 383 runs beautifully and the car is really unmolested, it is a great match.
It will be a lot of fun to drive without the apprehension of all the other idiots on the road, a great cruiser with a good amount of oomph off the line.
Now maybe, I will have someone else to cruise around town with and hit the shows and Friday/Saturday night cruise-ins.
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593593
03/16/14 02:06 PM
03/16/14 02:06 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
looks great
1981 Dodge D150 360 auto
Re: Quick Swap 318 to 383 [Re: basketcase] #1593594
03/16/14 04:11 PM
03/16/14 04:11 PM
thanks for the flowers
Another Mopar soon to be on the road again thanks to your help bro
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593595
03/16/14 11:53 PM
03/16/14 11:53 PM
Valve covers painted and installed.
The Duralast cut to fit wire set #1600 (90* plug boots) and #1601 (straight boot) worked better than expected! $15.00 each set
Running nice. I have to get the exhaust system done, I will try and find a shop tomorrow AM if possible.
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593596
03/16/14 11:54 PM
03/16/14 11:54 PM
that #7 wire is a bit long!
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593597
03/24/14 02:35 PM
03/24/14 02:35 PM
loaded on the trailer on the way to get the exhaust installed
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593598
03/24/14 02:40 PM
03/24/14 02:40 PM
Not much competition of custom muffler shops in my area so im at the mercy of this one.
Around here, most shops do only modern car and truck from the cat back and if you ask them about an old car, they seem very uninterested.
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593599
03/24/14 02:46 PM
03/24/14 02:46 PM
A WOPPING $800. later OUCH!
I bet I could have ordered it from summit or jegs for half that.
Can you say "Bait and switch"?.
After loading everything up on a trailer and dropping it off, knowing I had to have it done today, or I wouldnt have taken it to a shop. I would have done it myself.
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593600
03/24/14 02:51 PM
03/24/14 02:51 PM
I had to change out the intake manifold and carb. That old 2 bbl was giving me too much trouble, hard to start, popping/coughing on acceleration, unstable idle etc....
Now it lights right off.
I have to modify the throttle cable and kick down bracket to work properly and I still have to work on the bog issue but that will be for another time.
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593601
03/24/14 02:52 PM
03/24/14 02:52 PM
give her a bath
looks better not covered with dust.
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593602
03/25/14 08:55 AM
03/25/14 08:55 AM
New Kent, Va.
bobbyb Offline
bobbyb  Offline
New Kent, Va.
Looks Nice
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
Re: Quick Swap 318 to 383 [Re: bobbyb] #1593603
03/25/14 03:35 PM
03/25/14 03:35 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
just a TAD pricey. I've got a couple of shops around here, and none would have charged half that.
car looks great
Re: Quick Swap 318 to 383 [Re: basketcase] #1593604
03/25/14 05:53 PM
03/25/14 05:53 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Man you could have gone TTI for that kind of dough.
Cool though! I have a '67 Lite that was similar to yours when I got it. 383 is a great engine for a nice cruiser and driver. Nice car
Re: Quick Swap 318 to 383 [Re: GTX MATT] #1593605
03/27/14 10:14 AM
03/27/14 10:14 AM
I'm not very happy to say the least. He said it would run me $600 tops out the door. After loading it on the trailer and driving across town and dropping it off as agreed,
I get a call,
"its going to be a bit more, do you still want to get it done?"
Thats why I said "Bait and Switch" just the cost of going to pick it up without having it done and wasting the day too, I figured the $200 was worth not having to deal with finding another shop or having to install TTI's system a week or two later myself.
Some business are not being run like they were some years ago where your word meant something. The job was not done quite the way we agreed. It was supposed to be "serviceable" Un-bolt it to remove....NOT! some (not all) of the hangers have to be cut off
Lesson learned (I hope)
Mom.
Ricky Valdes
Re: Quick Swap 318 to 383 [Re: Copper Dart] #1593606
03/28/14 12:17 AM
03/28/14 12:17 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Nice job on the swap, it looks like it grew there. 318 cars are no fun to drive, the 383 makes it into a nice car.
Sheldon
Page 2 of 3 1 2 3
