Going to look at a sweptline... #1593528
03/16/14 01:14 AM
03/16/14 01:14 AM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
Going next week. It is supposed to be a clean truck, been sitting about 2 years, was driven to where its parked.
What should I look for? (Problems)
I do know it has spent its whole life in the TX panhandle. Rust shouldnt be a major issue. It is a wide bed truck.
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: Going to look at a sweptline... [Re: old_goat] #1593529
03/16/14 11:32 AM
03/16/14 11:32 AM
dogdays Offline
dogdays  Offline
Rust at the front body mount on the drivers side is what I'd look for first. Then the lower edge of the tailgate, I have two and they're both rusted through at the kickout below the vertical flat area. That one I can't figure out why.
If it's manual steering the box is a Saginaw 525, easy to fix and parts are easy to find. Kingpins will need to be done, most likely.
Door latches on the pre-68 ones, later had better locks.
Hydraulic clutch can be a bother, although replacement parts are easy to find.
Turn signal canceling is often broken, I just live with mine.
Important vehicle information is on a tag on the driver side doorpost.
All in all they're pretty simple and durable trucks, mine is 50 years old, lived through two collisions and is still hauling me over the mountains.
R.
Re: Going to look at a sweptline... [Re: dogdays] #1593530
03/16/14 12:31 PM
03/16/14 12:31 PM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
Thanks dogdays,
This one is a 63. If I get the truck, it will get a teardown and restomod. Thinking of a possible Dakota front frame clip, or maybe crown vic. More than likely big block power.
I am more concerned with body issues like the body mounts and gate rust.
84 D150 440/727
79 /6 swb D150
Re: Going to look at a sweptline... [Re: old_goat] #1593531
03/16/14 12:43 PM
03/16/14 12:43 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
One of the worst places are the cowl especially at the edges where the fenders meet the cab in front of the doors. There are oval clean-outs that had rubber plugs that never got cleaned-out and rust that edge badly. If it is full of leaves if can ever rot out the firewall behind the dash no matter where the truck came from originally.
JB Rhinehart, Realist
A-Body's RULE!
Re: Going to look at a sweptline... [Re: Rhinodart] #1593532
03/18/14 07:18 PM
03/18/14 07:18 PM
pana illinois
bigblock4x4 Offline
bigblock4x4  Offline
pana illinois
i will be driving mine soon,gonna drive it too fobes car show in clinton this fall,cant wait,it's fun,been poishing on it some,still dont look too bad
