Are all 727 BB trans. from 68 to 71 interchangeable? #1593446
03/15/14 08:14 PM
03/15/14 08:14 PM
Boston, MA
crocha617 Offline OP
Boston, MA
Would a 727 BB transmission from 1969 4 door fit in a 71 cuda ? Is there any tail shaft length differences?
Re: Are all 727 BB trans. from 68 to 71 interchangeable? [Re: crocha617] #1593447
03/15/14 08:22 PM
03/15/14 08:22 PM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
If it a big block 727 in the 4-door, it should go right in your 71 Cuda. You will have to have the 71 cuda transmission mount.
Re: Are all 727 BB trans. from 68 to 71 interchangeable? [Re: GLR] #1593448
03/15/14 10:43 PM
03/15/14 10:43 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
71 A-727 trans had part-throttle kickdown. That will not be on the 68 trans.
Re: Are all 727 BB trans. from 68 to 71 interchangeable? [Re: Vert] #1593449
03/16/14 11:42 PM
03/16/14 11:42 PM
Beans Cove Pa
Bumbalawski Offline
Bumbalawski  Offline
Beans Cove Pa
70 and up automatics had an ear cast in for column shift linkage brackets. 69 and back did not have the casting.
