Re: Hotchkis 76 Dart Build
[Re: DoctorDiff]
#1592973
01/13/15 05:39 PM
01/13/15 05:39 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
The rotors measure 13". I also have offset mounting brackets that move the caliper downward 1".
And that checks out to clear the tie rod and not change any caliper to inner rim clearance?
[Re: DoctorDiff]
#1592975
01/14/15 12:03 AM
01/14/15 12:03 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
Yes.
Do you have pictures and how much? Do they work in conjunction with the caliper adapters already provided in your kit or are they separate? Although, looking at the '76 Dart, it doesn't seem like he's using them.
[Re: DoctorDiff]
#1592977
01/14/15 01:21 AM
01/14/15 01:21 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Your calipers are longer, so the offset brackets (which you already have) are required.
Ah... So the kit on the '76 is an older Stage 4 kit?
[Re: Consulier]
#1592980
02/16/15 02:28 PM
02/16/15 02:28 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Very Nice! For the RacePak there is a formula to input into the software to program the IQ3 to get a speedo signal from the transmission if it has an electronic output. You have to wire the electronic output on the trans to a USM box and then input a value into the software. The formula for the value or "factor" as the RacePak guys call it is: tire height x 3.14 ÷ 12 ÷ 5280 ÷ rear gear ratio x 60 This is handy to have because the GPS speedo does not always connect when you need it or if you are in cities or tunnels The IQ3 will at times freeze up but I just reset mine on and off and it works fine
[Re: RylisPro]
#1592981
02/16/15 02:57 PM
02/16/15 02:57 PM
Posts: 256 USA
Consulier
USA
This is handy to have because the GPS speedo does not always connect when you need it or if you are in cities or tunnels.
Yeah, it's setup with the GPS pickup in the back window now. I'll see how it goes. I have the pieces to use the pickup in the trans if I want to go that route later.
I'm looking forward to the lap times and such in the Racepak. So glad I went with that instead of standard gauges. It's just so compact and seems pretty easy to deal with.
[Re: RylisPro]
#1592983
02/16/15 03:42 PM
02/16/15 03:42 PM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
The car looks great and sounds great! Getting close!
Couple questions: Are ya'll logging / monitoring brake pressure? Did ya'll cut down the front bumper to get it closer to the body on the sides?
Once again - looks and sounds awesome. Can't wait to see it running.
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: RylisPro]
#1592984
02/16/15 03:54 PM
02/16/15 03:54 PM
Posts: 256 USA
Consulier
USA
Cool seats by the way! Although I am surprised why you didn't go with a halo style seat to offer extra protection especially since you have a cage?
No Halo seats allowed at the 'Ring on Tourist days. I've got a Halo Sparco if I need to swap it in for anything serious. I had them put the center net in just in case those become required with Halo seats later.
Also I would recommend to install a sturdy back brace to your driver seat that ties to the horizontal bar right behind it. Makes the seating position soo much stiffer!
I've never had an issue with seats moving around too much. I'm ok with it for the moment.
[Re: Uhcoog1]
#1592985
02/16/15 04:02 PM
02/16/15 04:02 PM
Posts: 256 USA
Consulier
USA
No, haven't even ventured down that path yet.
When it gets to the body shop we'll fiddle with the bumper mods.
For 2015, other than putting a fiberglass bumper on the rear, there will probably be little to no work done on the interior finishing, or the body work. I'm not going to lose another season to making it look pretty.
[Re: Consulier]
#1592986
02/16/15 04:13 PM
02/16/15 04:13 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Awesome! Like the trunk firewall, oh and every damn thing else too....
Mopar to the bone!!!
[Re: Uhcoog1]
#1592988
02/16/15 09:23 PM
02/16/15 09:23 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
Love the car...sounds great as well.
I was curious as to why those lines to and from the master cylinder had to be flexible? I suppose I can understand the ones from the reservoir but not the others. Seems like hard plumbing would have worked fine and had less volume consumption.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: Uhcoog1]
#1592989
02/16/15 09:43 PM
02/16/15 09:43 PM
Posts: 256 USA
Consulier
USA
There is what looks like a honeywell type pressure sensor in the brake line. Is that something else? ha maybe I need a tutorial on which master cylinder is which.
Brake light pressure switch. Has Tilton pedals, it was easier than fabbing a standard switch mount.
