Re: Hotchkis 76 Dart Build
[Re: RichV]
#1592951
09/28/14 02:13 PM
09/28/14 02:13 PM
Posts: 1,145 ontario calif
ns1aar
ontario calif
Some early 60s chevy vans had a 4sp column
NS1AAR
[Re: dangina]
#1592952
11/17/14 08:23 PM
11/17/14 08:23 PM
Posts: 256 USA
Consulier
USA
[Re: NV69B7RR]
#1592957
01/12/15 02:28 PM
01/12/15 02:28 PM
Posts: 256 USA
Consulier
USA
[Re: Consulier]
#1592959
01/12/15 05:02 PM
01/12/15 05:02 PM
Posts: 2,432 NorCal
RylisPro
NorCal
I highly recommend getting the clear cover for the IQ3 250-DS-IQ3CVR The one without a flange
[Re: RylisPro]
#1592960
01/12/15 09:56 PM
01/12/15 09:56 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Love the build, helps me make up my mind on a lot of nick nack stuff. I will probably resign myself to nixing the glove box compartment for fuse box access and just have a tray in there for my registration and insurance to sit.
Mopar to the bone!!!
[Re: Consulier]
#1592961
01/13/15 02:28 AM
01/13/15 02:28 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
So you can rear mount these calipers... Maybe my rough and dirty approximation of an alignment was a little funky.
[Re: MuuMuu101]
#1592962
01/13/15 02:51 AM
01/13/15 02:51 AM
Posts: 27,468 So Cal
autoxcuda
So Cal
But what UCA's is he using? And what diameter rotors and what/who's brake setup?
[Re: autoxcuda]
#1592963
01/13/15 02:58 AM
01/13/15 02:58 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
He's using Dr Diff's, I asked him on FABO. I'd assume he's using Hotchkis' UCA's as they're building his car.
[Re: DoctorDiff]
#1592965
01/13/15 03:13 AM
01/13/15 03:13 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
That is my Stage 4 brake kit with Baer rotors and a slightly shorter caliper. I don't think it will clear the Hotchkis UCA, when mounted toward the rear, however.
My experience proves this to be true... Granted my alignment was pretty rough and dirty, the bleeder was literally sitting right underneath the UCA at full droop.
[Re: DoctorDiff]
#1592967
01/13/15 03:54 AM
01/13/15 03:54 AM
autoxcuda
So Cal
Are those 13" rotors or 14"?
[Re: autoxcuda]
#1592968
01/13/15 04:03 AM
01/13/15 04:03 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
It looks like the same kit as mine with 13" rotors. If they were 14" they'd fill up the wheel almost completely. Have you ever seen OzHemi's setup with 14" rotors on an 18" wheel?
[Re: autoxcuda]
#1592969
01/13/15 10:37 AM
01/13/15 10:37 AM
Posts: 256 USA
Consulier
USA
13", they say it clears, I've not been there to see it. If for some reason it doesn't, then they'll flip them around, or whittle up a new adapter to rotate the caliper down to clear.
Not way up there on my worry list at the moment...
