Page 5 of 8 1 2 3 4 5 6 7 8
Re: Hotchkis 76 Dart Build [Re: Consulier] #1592950
09/27/14 07:22 PM
09/27/14 07:22 PM
Seattle WA
RichV Offline
RichV  Offline
Seattle WA
http://www.slantsix.org/forum/viewtopic....36d3a48960c8886
If anyone knows how to get a column shift to work with a four speed in an early a body and still have reverse, post it up. I want one for an upcoming project after the Dart.
Here's some info on this subject.
Re: Hotchkis 76 Dart Build [Re: RichV] #1592951
09/28/14 01:13 PM
09/28/14 01:13 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Some early 60s chevy vans had a 4sp column
NS1AAR
Re: Hotchkis 76 Dart Build [Re: dangina] #1592952
11/17/14 07:23 PM
11/17/14 07:23 PM
USA
Consulier Offline
Consulier  Offline
USA
Some stuff I added to the thread on FABO today...
Some sheet metal work on the doors...
Re: Hotchkis 76 Dart Build [Re: Consulier] #1592953
11/17/14 07:28 PM
11/17/14 07:28 PM
USA
Consulier Offline
Consulier  Offline
USA
Bulkhead on the Hotwire Harness... yes this will all get wrapped when finalized.
Brake Bias mount...
Leaf Spring front hanger support...
Re: Hotchkis 76 Dart Build [Re: Consulier] #1592954
11/17/14 08:21 PM
11/17/14 08:21 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Very nice!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Hotchkis 76 Dart Build [Re: RylisPro] #1592955
11/21/14 12:50 PM
11/21/14 12:50 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
VERY NICE WORK!!!!!
Re: Hotchkis 76 Dart Build [Re: 70blackfish] #1592956
11/21/14 02:05 PM
11/21/14 02:05 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Beautiful! The level of fab work on your car is amazing! More pictures please!!
Re: Hotchkis 76 Dart Build [Re: NV69B7RR] #1592957
01/12/15 01:28 PM
01/12/15 01:28 PM
USA
Consulier Offline
Consulier  Offline
USA
Wheels are on and the car is on it's suspension at the moment...
I went cheap on the wheels to start with since I'm not sure where this will end up for tire size. They will always make good rain wheels. Got them from American Muscle. They are 18x10 at 24mm and weigh 20.9 lbs for $210 each. Didn't think that was too bad for a wheel of that weight and size.
Re: Hotchkis 76 Dart Build [Re: Consulier] #1592958
01/12/15 01:45 PM
01/12/15 01:45 PM
USA
Consulier Offline
Consulier  Offline
USA
Some more fab shots and details...
Wiring with OBDII Port that will be used for the RacePak.
Dual Battery switch and isolator that is used for the FIA legal kill switch. There is a button on the cowl and on the dash that is used to kill the car. Details on their site Armtech .
At least I have a piece of Carbon Fiber on the car...
Racepak and Dash layout
Fuel Cell and pump leads
Dual pumps mounted in a surge tank. Switch on the dash to flip between if one fails.
Remote oil filter mount
Re: Hotchkis 76 Dart Build [Re: Consulier] #1592959
01/12/15 04:02 PM
01/12/15 04:02 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I highly recommend getting the clear cover for the IQ3
250-DS-IQ3CVR
The one without a flange
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Hotchkis 76 Dart Build [Re: RylisPro] #1592960
01/12/15 08:56 PM
01/12/15 08:56 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Love the build, helps me make up my mind on a lot of nick nack stuff. I will probably resign myself to nixing the glove box compartment for fuse box access and just have a tray in there for my registration and insurance to sit.
Mopar to the bone!!!
Re: Hotchkis 76 Dart Build [Re: Consulier] #1592961
01/13/15 01:28 AM
01/13/15 01:28 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
So you can rear mount these calipers... Maybe my rough and dirty approximation of an alignment was a little funky.
Re: Hotchkis 76 Dart Build [Re: MuuMuu101] #1592962
01/13/15 01:51 AM
01/13/15 01:51 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
But what UCA's is he using? And what diameter rotors and what/who's brake setup?
Fall Fling 28 October 19, 2024 at Woodley Park, Van Nuys CA
300+ Mopars, 125+ swap, midway, Friday Malibu cruise,
Re: Hotchkis 76 Dart Build [Re: autoxcuda] #1592963
01/13/15 01:58 AM
01/13/15 01:58 AM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
He's using Dr Diff's, I asked him on FABO. I'd assume he's using Hotchkis' UCA's as they're building his car.
Re: Hotchkis 76 Dart Build [Re: autoxcuda] #1592964
01/13/15 02:01 AM
01/13/15 02:01 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
That is my Stage 4 brake kit with Baer rotors and a slightly shorter caliper. I don't think it will clear the Hotchkis UCA, when mounted toward the rear, however.
Re: Hotchkis 76 Dart Build [Re: DoctorDiff] #1592965
01/13/15 02:13 AM
01/13/15 02:13 AM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
My experience proves this to be true... Granted my alignment was pretty rough and dirty, the bleeder was literally sitting right underneath the UCA at full droop.
Re: Hotchkis 76 Dart Build [Re: MuuMuu101] #1592966
01/13/15 02:29 AM
01/13/15 02:29 AM
Santa Fe Springs, CA
Dan@Hotchkis Offline OP
I'll call the HPE guys tomorrow and get the skinny.
Re: Hotchkis 76 Dart Build [Re: DoctorDiff] #1592967
01/13/15 02:54 AM
01/13/15 02:54 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Are those 13" rotors or 14"?
Re: Hotchkis 76 Dart Build [Re: autoxcuda] #1592968
01/13/15 03:03 AM
01/13/15 03:03 AM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
It looks like the same kit as mine with 13" rotors. If they were 14" they'd fill up the wheel almost completely. Have you ever seen OzHemi's setup with 14" rotors on an 18" wheel?
Re: Hotchkis 76 Dart Build [Re: autoxcuda] #1592969
01/13/15 09:37 AM
01/13/15 09:37 AM
USA
Consulier Offline
Consulier  Offline
USA
13", they say it clears, I've not been there to see it. If for some reason it doesn't, then they'll flip them around, or whittle up a new adapter to rotate the caliper down to clear.
Not way up there on my worry list at the moment...
