'64 Cable Type Console Shifter to '66+ 727 #1592696
03/14/14 05:15 AM
03/14/14 05:15 AM
Tucson, AZ
Furious65 Offline OP
Tucson, AZ
Is it possible to adapt the cable operated console shifter in a '64 Polara 500 to work with the '66 and later 727?
Re: '64 Cable Type Console Shifter to '66+ 727 [Re: Furious65] #1592697
03/14/14 09:00 AM
03/14/14 09:00 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Your going to have to make some special pieces yourself. In this day and age of aftermarket cable shifters I don't see a reason why you couldn't adapt one to do what you need. Biggest issue will probably be getting the ratio correct. I don't see how you will be able to use the factory cable itself, but by replacing it with an aftermarket cable everything else from an aftermarket kit will bolt on the trans and function the same. Talk to any of your buddies you run GM or Ford. If they installed an aftermarket shifter in something they have the pieces you need left over in their box of parts. Then just buy a cable. Its all in how bad you want to do it.
...FAFO...
Re: '64 Cable Type Console Shifter to '66+ 727 [Re: skicker] #1592698
03/14/14 09:55 AM
03/14/14 09:55 AM
So Dak
GOLDENCOMMANDO Offline
So Dak
You can just order one from Imperial services.
http://www.imperialservices.net/Bparts.html
Re: '64 Cable Type Console Shifter to '66+ 727 [Re: GOLDENCOMMANDO] #1592699
03/14/14 11:59 AM
03/14/14 11:59 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
That's a cool set-up. Thx for the link for future reference!
...FAFO...
Re: '64 Cable Type Console Shifter to '66+ 727 [Re: skicker] #1592700
03/14/14 01:54 PM
03/14/14 01:54 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
If you call Imperial tell Steve if you get him that Rocky and his son Jesse sent you.He is pretty busy but is a great guy to deal with.Rocky
Chrysler Firepower
Re: '64 Cable Type Console Shifter to '66+ 727 [Re: therocks] #1592701
03/15/14 06:38 AM
03/15/14 06:38 AM
Tucson, AZ
Tucson, AZ
Thanks gentlemen! I figured it had to be possible.
Re: '64 Cable Type Console Shifter to '66+ 727 [Re: therocks] #1592702
03/15/14 09:11 AM
03/15/14 09:11 AM
moparx Offline
moparx  Offline
rocky, do you know if their turnaround time has improved ? seems there has been a lot of complaints about that in the past.
Re: '64 Cable Type Console Shifter to '66+ 727 [Re: moparx] #1592703
03/15/14 09:33 AM
03/15/14 09:33 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
He was way behind for a while for sure.he was supposed to be a lot better.I know when he shipped some mounts to me and the son it was quick.We both run his poly mounts on our cars.Rocky
Chrysler Firepower
