Re: Power steering wormshaft seal removal and replacement
[Re: J Brough]
#1591859
03/12/14 03:03 PM
03/12/14 03:03 PM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
Once you remove everything to get to the seal, just use a wood deck screw. You can drill a samll hole in the seal or just start the screw. Put one on one side and another on the other side and pull on them both at the same time. It comes right out.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
