300HP 360 Mag crate NET (or) 240HP 5.9L Mag GROSS HP? #1591828
03/12/14 10:03 AM
03/12/14 10:03 AM
the frozen wastes...
Pale_Roader Offline OP
Swears too much
Swears too much
I'm trying to figure out my options here.
I'm told a 5.9L Magnum is basically a 300HP Magnum crate engine, as far as internals and specs go. Basically take a 5.9L Magnum from a truck, swap on an RPM and proper carb, and headers, and i'll have a 300HP (gross) HP engine. But what would the NET be?
Guess i'm asking, what do an RPM intake, proper carb and headers ADD to the 5.9L's net 240-245HP?
Talking just stock, pull-out engines here, BEFORE i start messing with heads, cams, compression, etc.
Re: 300HP 360 Mag crate NET (or) 240HP 5.9L Mag GROSS HP? [Re: Pale_Roader] #1591829
03/12/14 11:43 AM
03/12/14 11:43 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Google the 2008 Hot Rod mag build.It's all there.
Leave the gun.......take the Cannoli's....Mike
Re: 300HP 360 Mag crate NET (or) 240HP 5.9L Mag GROSS HP? [Re: Pale_Roader] #1591830
03/13/14 01:46 AM
03/13/14 01:46 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
a bit, but not much without changing the cam.
Re: 300HP 360 Mag crate NET (or) 240HP 5.9L Mag GROSS HP? [Re: mike s] #1591831
03/13/14 06:44 AM
03/13/14 06:44 AM
Swears too much
Swears too much
Not really... i've seen it many times before and it just tells me what i already know. I'm curious what kind ov NET HP figures that stock engine (w RPM, carb and headers) would make behind a manual transmission.
I'm guessing that the as installed NET HP would be considerably lower than the rated 300 engine dyno HP.
Or how about REAR WHEEL HP figures for the 5.9L Magnum? Dont suppose anyone here has chassis-dyno'd a truck? or a car with a swapped 5.9L?
Re: 300HP 360 Mag crate NET (or) 240HP 5.9L Mag GROSS HP? [Re: jbc426] #1591832
03/13/14 06:45 AM
03/13/14 06:45 AM
Swears too much
Swears too much
I could do the math myself, but being smallblock-impaired, i have NOOO idea what headers and an RPM intake add over the stock manifolds and beer barrel.
Re: 300HP 360 Mag crate NET (or) 240HP 5.9L Mag GROSS HP? [Re: Pale_Roader] #1591833
03/13/14 02:17 PM
03/13/14 02:17 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
http://www.moparmusclemagazine.com/techa...p_crate_engine/
This is a very good read and should give you some good numbers on building a stockish 360 Mag.
Re: 300HP 360 Mag crate NET (or) 240HP 5.9L Mag GROSS HP? [Re: MarkZ] #1591834
03/13/14 02:49 PM
03/13/14 02:49 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
That 300 motor falls off where my stocker does with a carb & 92 model manifolds between 4800-5200 rpm
Re: 300HP 360 Mag crate NET (or) 240HP 5.9L Mag GROSS HP? [Re: BulletBob] #1591835
03/13/14 02:58 PM
03/13/14 02:58 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Myron (LocoMotion)is the man to talk to about a stocker style Magnum too
Re: 300HP 360 Mag crate NET (or) 240HP 5.9L Mag GROSS HP? [Re: BulletBob] #1591836
03/13/14 07:32 PM
03/13/14 07:32 PM
Swears too much
Swears too much
All these articles are in gross/crank engine dyno horsepower. That means nothing to me. Maybe i've been playing with Mustangs too long, but i want to know what its doing in NET HP or RWHP.
Re: 300HP 360 Mag crate NET (or) 240HP 5.9L Mag GROSS HP? [Re: Pale_Roader] #1591837
03/13/14 11:45 PM
03/13/14 11:45 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
IIRC, the 300 HP crate engine dyno'ed around 320HP, so I would guess around 280-290 ish net? Also, I'd be suprise if the 5.9 had an actual 240-245 HP in stock form as they all received the death flash that cut a bunch of timing and killed power (to compensate for the plenum leak they all had).
Re: 300HP 360 Mag crate NET (or) 240HP 5.9L Mag GROSS HP? [Re: Pale_Roader] #1591838
03/14/14 12:47 AM
03/14/14 12:47 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Got it, so why does it have to be in the context of this particular motor and build? Parasitic loss is going to be the same percentage regardless of what motor is in front of it. Get the percentage based loss of the accessories you're looking to run and apply it to your gross number.
I don't know what accessories eat up, but for drive line loss I see 15 and 18 percent tossed around a lot for manual and automatic respectively.
Re: 300HP 360 Mag crate NET (or) 240HP 5.9L Mag GROSS HP? [Re: MarkZ] #1591839
03/14/14 07:03 AM
03/14/14 07:03 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
[quote
And that is being generous, I'd use a higher number.
Chrysler engineer I know took an engine he setup on a dyno and then transferred it over to a vehicle and it lost 18% with a manual trans.
Of course with this being said, dynos differ on what they register for output.
"I think its got a hemi"
Re: 300HP 360 Mag crate NET (or) 240HP 5.9L Mag GROSS HP? [Re: MarkZ] #1591840
03/14/14 08:08 AM
03/14/14 08:08 AM
Swears too much
Swears too much
Now we're getting somewhere. I'd always used 17% loss from gross to net, which was based off no small amount ov math i did on the subject waaaaaaay back. Problem is, for the life ov me i cant remember how i came about those numbers, so i'm hesitant to use that here. I DO remember that in 1971, the Hemi made 425 gross HP and 350 net (about 17%). Thats not where my math came from though, but an interesting tidbit nonetheless. In fact, playing with the gross to net calcs in 1971 (the only year they rated with both methods) it typically comes out around 17%.
To keep things simple here too, i'm always talking about a stick car, with no accessories like power steering, AC, etc. Just the necessary stuff like alt, one pulley, etc.
What i'm doing here, is not so much building a bench engine, more just trying to figure out how these engines rate next to other modern engines. Still trying to figure out which way to go with the powerplant. Hard to compare a 300HP gross engine to a different 300HP net engine, and so on. I understand the 245 rating was a product ov crappy timing and tune, and equally bogus manifolds and exhaust... so for my intentions it just wont do. None ov the engines i'm comparing it to use gross ratings.
Re: 300HP 360 Mag crate NET (or) 240HP 5.9L Mag GROSS HP? [Re: Pale_Roader] #1591841
03/14/14 09:57 AM
03/14/14 09:57 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
I have a OBD-I 1995 5.9 Magnum v8 rated
230 SAE net HP at 4000 rpm
330 ft lbs at 3200
I know by measuring myself that the factory stock exhaust system had about 8 psi of back pressure at 4000 rpm,
and that the full throttle air to fuel ratio was a very rich 10.5 to 1 at 4000 rpm
I have entered all the stock specifications into a Performance Trends Engine Analyzer version 3.2 computer program and can get it to nearly match factory rated output:
230 SAE net peak HP at 4000 rpm
333 ft lbs peak torque at 3200 rpm
at an air fuel ratio of 12.5 to 1
The true richer 10.5 to 1 a/f probably reduces peak HP two to four percent
If i change the "Gross HP" specs to
Typical Dyno condions
no accessories
no fan
no water pump
tubular 4 into 1 headers 38 inches long 1.625 internal diameter
800 cfm exhaust rating
Output increases to
285 HP at 4300 rpm
383 ft lbs at 3400 rpm
exhaust pressure is 0.7 psi at 4300 rpm
So Gross conditions adds about 55 HP
or roughly 24%
note i am still using the factory design
"Beer Barrel" intake manifold with its long 15.5 inch runners which is optimized for about 3600 rpm
Substituting a single plane MPI style intake manifold with shorter, larger passage runners would add 20 to 30 Additional Gross HP
roughly
230 SAE net can be turned into
305 Gross HP
1998 Magnums with their
245 SAE net rating on OBD-II
had less restrictive exhaust systems,
slightly less flow fuel injectors,
no EGR,
almost no internal plenum center divider
and a longer intake duration camshaft
compared to my 1995 model
The 1998 camshaft might be good for another 10 Gross HP
so
245 SAE net might become
315 Gross
Performance Trends estimates that their computer model output guesses are within
6% of actual HP and Torque
95% of the time
Re: 300HP 360 Mag crate NET (or) 240HP 5.9L Mag GROSS HP? [Re: Pale_Roader] #1591842
03/14/14 10:04 AM
03/14/14 10:04 AM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
Gross, net and RWHP are all different from each other, and add in the ever changing standards that are used in the industry to make such measurements and you will understand that these types of comparisons become completely meaningless.
Knowing the quality/performance potential of the current exhaust and induction system will have the largest influence on the hp change from one set-up to the other. Then call it what ever hp gain that makes you happy
Re: 300HP 360 Mag crate NET (or) 240HP 5.9L Mag GROSS HP? [Re: BSB67] #1591843
03/14/14 02:35 PM
03/14/14 02:35 PM
dogdays Offline
dogdays  Offline
Pale Roader, go back to the store and buy either apples OR oranges. You are confusing the ways horsepower is rated.
"Gross" horsepower is how the 1970 engines were rated. No accessories, and corrected to standard conditions, something like that.
Net horsepower is how later engines are rated, still on a dyno but with all accessories and I believe exhaust systems, also the standard correction factor may be a little less generous.
They are both way different than rear wheel horsepower. Rear wheel horsepower should be something like the Net number, minus the 15 - 25% drivetrain losses.
R.
Re: 300HP 360 Mag crate NET (or) 240HP 5.9L Mag GROSS HP? [Re: dogdays] #1591844
03/14/14 03:31 PM
03/14/14 03:31 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
All Magnum engines were tested and rated w/accessories,water pump and alt working.Losses are not the same as the 60's.Bracketry, pumps belts,alt itself are all less drag.Engines were off the line everyday engines once production was started.Yes they may have had a different part or 3 but that was only to test new parts.BTW tested with the exact exh back pressure as the vehicle.
Where do you guys get this misinformation you are posting?
Re: 300HP 360 Mag crate NET (or) 240HP 5.9L Mag GROSS HP? [Re: mike s] #1591845
03/14/14 03:39 PM
03/14/14 03:39 PM
Wisconsin,USA
Bzzzz Offline
Bzzzz  Offline
Wisconsin,USA
Maybe HotrodDave will chime in too! he messes with magnums quite a bit.. here is a good source too www.magnumswap.com
2005 Dodge 1500 Slt Hemi
2008 Chrysler PT cruiser
1984 Dodge D250
1978 Dodge D100 Adventurer
1964 Meyers Manx Dunebuggy
Re: 300HP 360 Mag crate NET (or) 240HP 5.9L Mag GROSS HP? [Re: mike s] #1591846
03/14/14 06:44 PM
03/14/14 06:44 PM
dogdays Offline
dogdays  Offline
So I said "with all accessories and I believe exhaust systems" how is that different than what you said?
There were, however, a lot of misconceptions starting with the OP.
R.
Re: 300HP 360 Mag crate NET (or) 240HP 5.9L Mag GROSS HP? [Re: dogdays] #1591847
03/15/14 03:46 AM
03/15/14 03:46 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
R.
I should have noted I agreed with you.I was pointing out the absolute nonsense stated by others.
