1973-74 RR Wheel well trim fastener? #1591614
03/11/14 07:42 PM
03/11/14 07:42 PM
PA
RoadRunner73 Offline OP
PA
Got wheel well trim for my 73 RR, didn't haven't on when I bought the car just the holes. I noticed the ones I got don't have fasteners or anything to go into the holes around the wheel well, what type of fasteners are to be used?
1973 Plymouth Road Runner
Re: Wheel we'll trim fastener? [Re: RoadRunner73] #1591615
03/11/14 08:08 PM
03/11/14 08:08 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Chrome plated Phillips drive button head sheet metal screws
I am truckless..
Re: Wheel we'll trim fastener? [Re: 340SHORTY] #1591616
03/11/14 08:32 PM
03/11/14 08:32 PM
PA
PA
There are no holes in the trim :-)
Re: Wheel we'll trim fastener? [Re: RoadRunner73] #1591617
03/11/14 09:22 PM
03/11/14 09:22 PM
Rome, Ga
sbhpcb Offline
sbhpcb  Offline
Rome, Ga
I takes a spring clip simular to a door panel clip
Re: Wheel we'll trim fastener? [Re: sbhpcb] #1591618
03/11/14 10:19 PM
03/11/14 10:19 PM
PA
PA
Know where I can get some? Thanks
Re: Wheel we'll trim fastener? [Re: RoadRunner73] #1591619
03/12/14 12:06 PM
03/12/14 12:06 PM
PA
PA
anyone know where I can get these fasteners?
Re: Wheel we'll trim fastener? [Re: RoadRunner73] #1591620
03/12/14 11:19 PM
03/12/14 11:19 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Not sure what you have near you but most local auto body supply shops have a display with different styles and types of clips..Spring clips included...That way you can take the trim along for the correct size..
Re: Wheel we'll trim fastener? [Re: screamindriver] #1591621
03/13/14 09:33 AM
03/13/14 09:33 AM
PA
PA
Thanks - Ill try that out, Just want it on the car ASAP since it worth more than my life!
Re: Wheel we'll trim fastener? [Re: RoadRunner73] #1591622
03/13/14 10:11 PM
03/13/14 10:11 PM
Harrisburg, Pa.
Harrisburg, Pa.
I was lucky...The 73 RR I restored did'nt have the wheelwell trim...The finding headlight buckets and rear bumper trim were all the fun I needed..
Re: Wheel we'll trim fastener? [Re: screamindriver] #1591623
03/14/14 09:23 AM
03/14/14 09:23 AM
PA
PA
Sweet ride - I came very close to just filling the holes in but I thought it would look really sharp with the trim... searched for months finally go it but didnt have clips cause they weren't on a car.
Re: Wheel we'll trim fastener? [Re: RoadRunner73] #1591624
03/15/14 01:25 AM
03/15/14 01:25 AM
Ma, USA North of Boston
74SatSundance Offline
Well, here is some pics for ya.
I lucked out and was able to reuse most of mine after a repaint.
And I was able to get some more from a junkyard car 3 years ago that had some still on it.
Unfortunately I don't know who is making them, but there are some large fastner companies out there.
As somebody said, you might try a local paint supply shop, as they might have a book to look them up or maybe have some pictures or better yet a display board with different fastners on it.
And the rear wheel trim, on the very bottom ends should have holes for screws. I thought it was weird that it was done that way.
Oh, I don't suppose that where you found your trim, that they might have more? I could use a set of rear wheel trim.
Re: Wheel we'll trim fastener? [Re: 74SatSundance] #1591625
03/15/14 01:31 AM
03/15/14 01:31 AM
Another, these are chrysler OEM clips from the junkyard car.
Re: Wheel we'll trim fastener? [Re: 74SatSundance] #1591626
03/15/14 02:53 AM
03/15/14 02:53 AM
St Louis, Missouri
Runnin74 Offline
Runnin74  Offline
St Louis, Missouri
That is what mine look like.
Re: Wheel we'll trim fastener? [Re: 74SatSundance] #1591627
03/15/14 02:56 AM
03/15/14 02:56 AM
St Louis, Missouri
Runnin74 Offline
Runnin74  Offline
St Louis, Missouri
Here is a pic of the rear trim holes.Instead of a hole in the end of the trim like the rear, the front trim pieces use a clip that has a threaded screw which fits though a hole in the lower wheel well and a sheet metal nut on the inside.
Re: Wheel we'll trim fastener? [Re: 74SatSundance] #1591628
03/15/14 09:08 AM
03/15/14 09:08 AM
PA
PA
Awesome! Pictures help a lot! And yes the back ones do have holes for screws, I assume they use the stainless screw with rubber on the back?
I got really luck on the trim - guy was selling a satellite on eBay with trim on and I asked about them, turned out he had a whole other set that don't appear to have been on a car. Only problem was no fasteners!
Another question, is the black insert painted, mine have some small scratches in the black but in other spot it almost looks like a thin black rubber or something?
Re: Wheel we'll trim fastener? [Re: RoadRunner73] #1591629
03/15/14 11:46 AM
03/15/14 11:46 AM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
Here's the spring clip
Common sense is a flower that does not grow in everybody's garden
Re: Wheel we'll trim fastener? [Re: Ron_M] #1591630
03/15/14 11:47 AM
03/15/14 11:47 AM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
another view
Re: Wheel we'll trim fastener? [Re: Ron_M] #1591631
03/15/14 11:49 AM
03/15/14 11:49 AM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
Should clean up after hitting it with a small wire brush in a Dremel tool. The nut sometimes has a (usually?) plastic crown (not shown).
Re: Wheel we'll trim fastener? [Re: Ron_M] #1591632
03/19/14 05:17 PM
03/19/14 05:17 PM
PA
PA
Not really able to find sets of these, I found a guy who has them NOS for all 4 wheel wells for $100... seems to be a little much but I am wondering if it would be worth it to just have the right clips... thoughts????
Re: Wheel we'll trim fastener? [Re: RoadRunner73] #1591633
03/21/14 11:07 AM
03/21/14 11:07 AM
PA
PA
Anyone?
