External oil pan pickup ?
#1591323
03/11/14 02:04 AM
03/11/14 02:04 AM
Posts: 4,701 On the parachute mount
n20mstr
Has anyone ever just used a bulkhead fitting or welded a bung on the side of a pan (basically NO internal pickup) ?
....BAD A$$ STREET CAR.....
Re: External oil pan pickup ?
[Re: n20mstr]
#1591324
03/11/14 02:07 AM
03/11/14 02:07 AM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
no for a couple of reasons.
the oil will be passing by the fitting, it goes in the side it can suck air and its also not in the center. you don't need a swinging one if you have baffles that close but you do need one in the center back about 1/2" off the floor.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: bigtimeauto]
#1591325
03/11/14 02:10 AM
03/11/14 02:10 AM
n20mstr
Bob I have been running static pickups for years. Just wondering why this won't work. The pickup in the pan has the fitting screwed into it. Was wondering if I could just eliminate the pickup
[Re: bigtimeauto]
#1591327
03/11/14 02:22 AM
03/11/14 02:22 AM
n20mstr
Ok a screen it is.....good thing it's still cold out. The wife won't notice that I cut a piece of screen out of the screen door!
[Re: FastmOp]
#1591335
03/11/14 01:38 PM
03/11/14 01:38 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I think the OP has a valid question, WHY? It seems back in the 18 hundreds some one thought that the oil pick up needed a screen. That probably was needed back then as oil was not refined very well, I read in a 1927 STAR [ that is a car ] owners maintenance manual. If you loose oil pressure, remove the oil pan and clean the lint from the oil pickup screen. Then there was also a baffle added for some reason on some engines. Was this to limit the oil flow, straighten out flow? every engine I have taken apart had a pickup screen 3-4" in diameter, some baffled some not. To use a pickup or not? I agree with having a screen to protect the oil pump, but a pickup from the 18 hundreds? The question is WHY?
[Re: n20mstr]
#1591337
03/11/14 02:17 PM
03/11/14 02:17 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Let us know how that works out for you
[Re: 440Jim]
#1591340
03/11/14 05:31 PM
03/11/14 05:31 PM
Posts: 52 San Diego, USA
SoCalRacer
San Diego, USA
Any of those pickups would be better than just a fitting in the side of the pan. You need to capture as much oil as possible when racing, and properly placed pickups (especially swinging) help do that. When under acceleration or deceleration oil is sloshing around like trying to run with a dishpan full of water, and a lot of oil is up in the motor so the pan level will be lower. Do you really want to just *hope* that little fitting is always covered? In a static situation you'd be fine, but once the car is moving...
I see this as a risk/reward situation. What, other than a little cash, is being saved? Is it worth risking the motor over <$100?
If it ain't broke ... you're not pushing it hard enough.
