Restoring 66-67 bucket seatbacks #1591218
03/10/14 08:06 PM
03/10/14 08:06 PM
Niwot, CO Formerly denn...
dynorad Offline OP
dynorad  Offline OP
Dos anyone have a good method to retexture the vinyl coated metal seatbacks? I have some with scuffs and have not had any luck so far. I want the repair to be undetectable if possible.
Re: Restoring 66-67 bucket seatbacks [Re: dynorad] #1591219
03/10/14 08:13 PM
03/10/14 08:13 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
This might work, don't know. Put some oil or slick wet substance on a section of the vinyl then take a high quality rtv or other sealer and put over the slick section. After it has cured pull it off and it should have the pattern imbedded in it. Now the tricky part,quickly heat one spot at a time with a small torch and quickly press down with the sealer and quickly pull off. You need the vinyl kind of fluid so it can retain the pattern off of the sealer.
Re: Restoring 66-67 bucket seatbacks [Re: 71birdJ68] #1591220
03/10/14 11:52 PM
03/10/14 11:52 PM
dynorad Offline OP
dynorad  Offline OP
I have tried a kit that is meant to do just that. I have a good grain pattern molded. The part that doesn't work is getting the texture into the patch vinyl.Press lightly and the pattern doesn't transfer, and press hard and the pattern flattens out. I have also tried epoxy, which gives a nice texture but the outline of the patch is easily visible.
Re: Restoring 66-67 bucket seatbacks [Re: dynorad] #1591221
03/11/14 02:59 PM
03/11/14 02:59 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
I had them powder coated wrinkle finish...looks great and its durable.
Re: Restoring 66-67 bucket seatbacks [Re: R/T1968R/T] #1591222
03/11/14 03:24 PM
03/11/14 03:24 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
I'm liking this idea for mine!
Re: Restoring 66-67 bucket seatbacks [Re: R/T1968R/T] #1591223
03/11/14 03:39 PM
03/11/14 03:39 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
I scraped off the vinyl texture, did some body work on the metal backing and painted mine. I think they look twice as nice as that ugly texture..
ALOT of work scraping off the texture.. I hot tanked em, sent em to the metal dipper, neither of these worked at all.. Used a torch with a razor blade scraping tool, then DA'd the rest of it..
Re: Restoring 66-67 bucket seatbacks [Re: dynorad] #1591224
03/12/14 11:39 AM
03/12/14 11:39 AM
Denver
E
Explodo Offline
Explodo  Offline
E
Denver
Why not just get matching vinyl and apply that? That's been my plan for when I get to that. I'd always assumed that that's what was on he back of the seats since that's what it looks like.
'67 440 Satellite
Re: Restoring 66-67 bucket seatbacks [Re: Explodo] #1591225
03/14/14 08:21 PM
03/14/14 08:21 PM
dynorad Offline OP
dynorad  Offline OP
I'll consider the wrinkle finish idea. There are some very tight curves on the seatback that would be very difficult to get the vinyl to follow.
Nobody's had any luck with original finish?
I have attached a picture from the GTX's maiden voyage last summer.
