thermoquad jets and rods #1590641
03/09/14 09:47 PM
03/09/14 09:47 PM
New Brunswick Canada
copperSwinger Offline OP
I dont have access to an A/F meter, and this carb has been fiddled with and could have non-stock components.
The engine in question is a 340 mildly built w/stock intake, x heads, and comp xe268 cam. Read:Nothing crazy
the carb is off a bigblock (75 400 or 77 440, i cant remember right now)
The Question is, what size jets and rods would you think is a good fit, or baseline for a street driven 4speed? Ive seen a mopar muscle article use 095 jets and #2145 rod on a seemingly mild 360(not many details). Does this sound about right? I dont drive at high altitude either
I'll take it apart and compare to what you guys recommend.
Re: thermoquad jets and rods [Re: copperSwinger] #1590642
03/09/14 10:23 PM
03/09/14 10:23 PM
Bakersfield, CA
Jared_Jordan Offline
Bakersfield, CA
My stocker carb has a 4099 primary jet and a 5110 secondary that's been drilled to approx. .135". Running the 2002 metering rod (.065/.052/.040 steps IIRC). I'm actually surprised at how well behaved it is around the pits and I'm running more cam duration than you will be.
Re: thermoquad jets and rods [Re: Jared_Jordan] #1590643
03/10/14 02:41 AM
03/10/14 02:41 AM
Gilbert, AZ
Aspen7695 Offline
Aspen7695  Offline
Gilbert, AZ
Jared, Have you given any thought to taping the primary jet seats to use Holley jets. You will not have to use the metering rods. It is a lot easier to change primary jet sizes when you are tuning.
Raul
Re: thermoquad jets and rods [Re: copperSwinger] #1590644
03/10/14 12:50 PM
03/10/14 12:50 PM
Az
Crizila Offline
Crizila  Offline
Az
what's the carb # on the edge of the throttle plate?
Fastest 300
Re: thermoquad jets and rods [Re: Crizila] #1590645
03/10/14 02:24 PM
03/10/14 02:24 PM
6545S 74 up 44 non smog if im not mistaken
Re: thermoquad jets and rods [Re: copperSwinger] #1590646
03/10/14 03:16 PM
03/10/14 03:16 PM
Az
Crizila Offline
Crizila  Offline
Az
went on 74 -77 440 - truck.
Pri jet = .098
Sec jet = .137
Rod = 75-2024 3 step - .066, .054, .040 ( econo, mid,power.
Bore = 1 1/2"
strip kit #10-203.
Start here to verify all the correct stuff is in it and make your mods from there. Shouldn't need to do much to it with minor engine mods. Should run good!
Fastest 300
Re: thermoquad jets and rods [Re: Crizila] #1590647
03/10/14 06:40 PM
03/10/14 06:40 PM
Thanks a lot that helps
