How do I remove an A body dash frame?
#158931
11/29/08 08:22 PM
11/29/08 08:22 PM
Posts: 2,059 NW/Indiana - Chi town
ricomondo
It's all disconnected, except for 5 or so bolts and the the bolt heads seem to be covered by a strip of the windshield rubber molding. Do I really have to remove the windhshield molding, glass etc, to get the dash frame out?? Or is there some slick trick to this? And I thought taking an E body dash frame out was a pain in the dupa.... Thanks...
GY3 71 Demon 340
Re: How do I remove an A body dash frame?
[Re: AdamR]
#158935
11/29/08 09:40 PM
11/29/08 09:40 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
You can get under the dash with a die grinder and cut the bolts and clips. Then put in new clips and run the bolts from the bottom up.
I've heard Jim Lusk discribe it like that before also.
You can do it without taking the windshield out.
[Re: autoxcuda]
#158936
11/29/08 10:18 PM
11/29/08 10:18 PM
Posts: 4,150 lewiston, ID
cornucopia
lewiston, ID
[Re: AdamR]
#158937
11/29/08 10:37 PM
11/29/08 10:37 PM
340dart4spd
Parts Problem
Parts Problem
Good Luck with that.....kinda half A$$ if you ask me...
[Re: 340dart4spd ]
#158938
11/29/08 11:24 PM
11/29/08 11:24 PM
Posts: 7,978 Bethel Ct
AdamR
Bethel Ct
I never said I would do it that way but if you dont want to pull the glass, buy a new gasket and pay to have it re-installed what choice do you have.
I bet most people would never even notice the bolts upside down
[Re: ricomondo]
#158942
11/30/08 12:52 AM
11/30/08 12:52 AM
autoxcuda
So Cal
Actually, that doesnt sound half bad. As mentioned, I'd hate to have to pay to have the windshield R & R'd just to put the dash frame in, but depends on the cost. Plus Id have to pay to have the windshield people come out twice; once to pull it, then again to install it once the new dash frame was in place.
And you take the chance of the windsheild guys screwing something up like your trim or paint.
I'll wait to see if anyone else chimes in with some ideas, but right now, that one is winning.
I know people here and other lists have done it without taking out the windshield. PM Jim Lusk
