1970 Dart speedometer cable exploded. UPDATE!
#1589089
03/07/14 01:40 AM
03/07/14 01:40 AM
Posts: 29,662 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
This is both ends of the parted cable, the transmission end at top, the end where it parted inside the jacket shown at bottom is about 9" away, I bent it for the photo.
If the odometer / speedometer head seized up, what is the fix?
Could it be anything else? Pinion gear clocked wrong?
Or?
Re: 1970 Dart speedometer cable exploded. Cause?
[Re: Pacnorthcuda]
#1589093
03/07/14 03:05 AM
03/07/14 03:05 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
lack of lube. needs more whale oil.
I am truckless..
[Re: Alaskan_TA]
#1589094
03/07/14 03:20 AM
03/07/14 03:20 AM
RapidRobert
When you get the new (or used) cable take the inner cable & put it in the trans & run it to confirm you're good on that end then take it out & stick the other end in the speedo head & spin it by hand or with a drill to see if that end is good also to confirm that the problem was confined to the cable itself
[Re: Alaskan_TA]
#1589095
03/07/14 10:43 AM
03/07/14 10:43 AM
Posts: 21,091 Niles , Ohio
therocks
Niles , Ohio
I agree it looks dry.Ive seen them do that before though.My 65 I put a new inner in.It lasted about 2 days and twisted apart.I finally used the inner that my kid pulled from his 62 that was OE.Usually the cable just snaps.Looks like maybe the outer had a burr that finally caught the inner and tore up both.Rocky
Chrysler Firepower
1970 Dart speedometer cable exploded. Update!
[Re: DusterJeff]
#1589098
03/12/14 11:58 PM
03/12/14 11:58 PM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
The replacement cable arrived today, I ensured that it was properly lubricated. I installed the replacement cable into the transmission & routed it in the factory path. With the speedometer end hanging below the dash, I started the car with the rear wheels off the ground and ensured that the cable spun when I put the car in gear. Car off. Cable hooked to speedometer. Car started, put in gear. The cable snapped again! So, what would cause a speedometer to lock up? ![](/ubbthreads/images/graemlins/shruggy.gif)
Re: 1970 Dart speedometer cable exploded. Update!
[Re: GKMOPAR]
#1589102
03/13/14 10:13 PM
03/13/14 10:13 PM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
I still need to know the answer if anyone knows what to look for or if it can be fixed?
Right now I am looking for a replacement unit so I can use it for parts, just in case. I see no reason to open this one up until I find a donor.
Re: 1970 Dart speedometer cable exploded. UPDATE!
[Re: Alaskan_TA]
#1589103
03/14/14 07:56 AM
03/14/14 07:56 AM
therocks
Niles , Ohio
Pull the dash with speedo.Then get a short piece of cable and see if the speedo is frozen.With a complete new cable and the bottom turning it has to be the speedo.Rocky
Chrysler Firepower
[Re: mopar_man]
#1589105
03/14/14 01:56 PM
03/14/14 01:56 PM
therocks
Niles , Ohio
I think he installed a complete assembley.If not it might have a burr in the sheath.Rocky
Chrysler Firepower
