Mopar techs or parts guys i need help iden. this part #1588851
03/06/14 06:53 PM
03/06/14 06:53 PM
minnarusta
TX9H6E4CUDA Offline OP
minnarusta
As some of you know my battery started leaking all over the trunk of my 2006 300C. I am trying to repair all the pieces damaged. I've been to three dealers and they can't id this part. It sits next to the battery drain infront of the the battery tray. I can't get a part number off the piece as its so corroded. Anyone able to help
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: Mopar techs or parts guys i need help iden. this part [Re: TX9H6E4CUDA] #1588852
03/06/14 07:05 PM
03/06/14 07:05 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I'm guessing fuel pump or sending unit. But I'm thinking fuel pump?
Wow we have 07 300 that has been sitting all winter. I just charged the battery last weekend after my wife emptied the trunk so we could get to it.
Why did your battery leak? makes me nervous.
Re: Mopar techs or parts guys i need help iden. this part [Re: Challenger 1] #1588853
03/06/14 07:07 PM
03/06/14 07:07 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Clean the corrosion and acid off the part and then see if you can identify it.
Re: Mopar techs or parts guys i need help iden. this part [Re: stumpy] #1588854
03/06/14 07:17 PM
03/06/14 07:17 PM
minnarusta
minnarusta
Challenger1
https://board.moparts.org/ubbthreads/show...rue#Post8062943
I don't know what caused the failure. Its a factory battery.
I have tried to clean it off bit the part is so brittle it just falls apart if I even breath on it.
Re: Mopar techs or parts guys i need help iden. this part [Re: TX9H6E4CUDA] #1588855
03/06/14 07:25 PM
03/06/14 07:25 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
A battery temp sensor would be my guess, the temp of the battery is one factor in calculating the charging voltage.
"I think its got a hemi"
Re: Mopar techs or parts guys i need help iden. this part [Re: Challenger 1] #1588856
03/06/14 07:26 PM
03/06/14 07:26 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
In the tank which is accessed from the rear passenger seat bottom.
Re: Mopar techs or parts guys i need help iden. this part [Re: gdonovan] #1588857
03/06/14 07:28 PM
03/06/14 07:28 PM
Alberta, Canada
K
krisiesmopes Offline
K
Alberta, Canada
DO NOT UNPLUG IT!!! That is the self destruct sensor.
Re: Mopar techs or parts guys i need help iden. this part [Re: TX9H6E4CUDA] #1588858
03/06/14 07:31 PM
03/06/14 07:31 PM
Ohio
john55 Offline
john55  Offline
Ohio
looks like a through body connector, are there wires connected on the bottom side under the trunk, possibly ABS... 2 twisted pairs of wires, I guess ABS.... , I'll look it up...
That's an ABS thru body connector, the wire colors match up to rear ABS sensors , I'd just clean around the area, make sure the ABS light doesn't stay on after replacing the battery
Re: Mopar techs or parts guys i need help iden. this part [Re: gdonovan] #1588859
03/06/14 07:34 PM
03/06/14 07:34 PM
The Grand State of Confusion-O...
SKR8PN Offline
SKR8PN  Offline
This would be my guess as well.
Karma has no menu. You get served what you deserve.
Re: Mopar techs or parts guys i need help iden. this part [Re: SKR8PN] #1588860
03/07/14 04:02 AM
03/07/14 04:02 AM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
I have an 05 Magnum - maybe this is the part? Its in front of the battery tray - towards the front of the car.
Re: Mopar techs or parts guys i need help iden. this part [Re: Tom_440] #1588861
03/07/14 04:13 AM
03/07/14 04:13 AM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
closer
Re: Mopar techs or parts guys i need help iden. this part [Re: TX9H6E4CUDA] #1588862
03/07/14 12:13 PM
03/07/14 12:13 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
A wiring diagram will tell you what it is !
Re: Mopar techs or parts guys i need help iden. this part [Re: 62maxwgn] #1588863
03/07/14 02:10 PM
03/07/14 02:10 PM
Ohio
john55 Offline
john55  Offline
Ohio
The Plymouth Win You Over Beat Goes On
Re: Mopar techs or parts guys i need help iden. this part [Re: john55] #1588864
03/07/14 03:27 PM
03/07/14 03:27 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
I know, right?
Re: Mopar techs or parts guys i need help iden. this part [Re: john55] #1588865
03/08/14 02:57 PM
03/08/14 02:57 PM
minnarusta
minnarusta
Ding ding ding
I went to the fifth dealer and the guy found it......it can only be bought with a full harness. I was able to get another one off a car at a salvage yard. Thanks again fir the help!!!!!
Re: Mopar techs or parts guys i need help iden. this part [Re: TX9H6E4CUDA] #1588866
03/08/14 05:46 PM
03/08/14 05:46 PM
Ohio
john55 Offline
john55  Offline
Ohio
