73 cuda seat for a 73 Road Runner? #1588608
03/05/14 07:43 PM
03/05/14 07:43 PM
PA
RoadRunner73 Offline OP
PA
Looking for a seat core to replace mine, anyone know if I can use a 73 cudas in my 73 RR??
1973 Plymouth Road Runner
Re: 73 cuda seat for a 73 Road Runner? [Re: RoadRunner73] #1588609
03/06/14 11:18 AM
03/06/14 11:18 AM
Rome, Ga
sbhpcb Offline
sbhpcb  Offline
Rome, Ga
Not sure on the overall "LOOK", But I think the E bodies and B bodies may use the same floor pan? Check on AMD or Goodmark's website to see if the floors are the same part number? If the floor is the same then You would know it would bolt up.
Re: 73 cuda seat for a 73 Road Runner? [Re: sbhpcb] #1588610
03/06/14 11:55 AM
03/06/14 11:55 AM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
The seat itself will bolt in. The 70-74 E-body seats have the same seat bolt pattern as the 71-74 B-body cars...but, the actual size of the seat is larger on a 73 B-body. I am not sure if it is just the foam that was used or if the actual frame is larger but they are a little different.
