SLIDERS INSTALLED..........UPDATE! #1588563
03/05/14 04:18 PM
03/05/14 04:18 PM
State of confusion
Thumperdart Offline OP
State of confusion
I`ll get picks later but it`s actually tighter than my poly lubed up shackles.............. I assume some has to do w/em being flat and having no arch but after I bring my pinion angle back to around 4-5 instead of 7 we`ll drive it and see. Thankxx 4 all of the help.
Shackles kick azz............love em. Car`s way more stable and shoot and point and it goes. It`s really trying to hook up on the street but maybe next Sat. I can take care of a long over due street race and see what happens.............
Re: SLIDERS INSTALLED........................... [Re: Thumperdart] #1588564
03/05/14 04:24 PM
03/05/14 04:24 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Cool! Now go get us some 60' testing!! Just did my install but the snow falling is depressing
Re: SLIDERS INSTALLED........................... [Re: SpareParts] #1588565
03/05/14 04:52 PM
03/05/14 04:52 PM
State of confusion
State of confusion
I just checked em out and it seems after welding, the boxes have bowed out an 1/8 in. at the bottom causing a slight bind on the bearings so back to the grind....
Re: SLIDERS INSTALLED........................... [Re: Thumperdart] #1588566
03/05/14 05:15 PM
03/05/14 05:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Tack them good then run short hot welds about 1/2"
to max 1"... let it cool before hitting the next spot
Re: SLIDERS INSTALLED........................... [Re: Thumperdart] #1588567
03/05/14 05:18 PM
03/05/14 05:18 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
You'll like them. The rise is reduced quite a bit. I use never-sieze on the tracks once on a while on mine.
Yeah, it's got a smallblock.
Re: SLIDERS INSTALLED........................... [Re: Thumperdart] #1588568
03/05/14 05:43 PM
03/05/14 05:43 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Pull them together with a C clamp?
Re: SLIDERS INSTALLED........................... [Re: SpareParts] #1588569
03/05/14 05:58 PM
03/05/14 05:58 PM
State of confusion
State of confusion
That and a big hammer and all`s well and no more bind. They`re already welded in Mike. There`s a collar that`s the same od as the bearings inner that the bolt goes through so instead of the bearing taking the hit cornering, I found some washers slightly smaller than the outer diameter of the bearings and installed em on the inside of the bearings w/a slight gap and we`re golden. Don`t like the idea of the bearing takin the beating when the washer can better spread the load..........
Re: SLIDERS INSTALLED........................... [Re: Thumperdart] #1588570
03/05/14 07:36 PM
03/05/14 07:36 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I have a set of sliders that I bought from Alex Denysenko at www.moneymakerracing.net and I intend to use them on the Ramcharger. I have a large piece of square tubing that I will attach to the frame as a crossmember. The sliders will fit nicely on the bottom and the down tubes from the roll cage will attach at the top. I did the axle flip and have the Dana 60 above the springs with some long "Chevy" shackles and I don't like that (I don't think it is stable enough at the hit). I will post some pictures when I am done with it.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: SLIDERS INSTALLED........................... [Re: Polarapete] #1588571
03/05/14 07:47 PM
03/05/14 07:47 PM
State of confusion
State of confusion
Good luck and 8 beers later mine was finished............
Re: SLIDERS INSTALLED........................... [Re: Thumperdart] #1588572
03/06/14 04:01 PM
03/06/14 04:01 PM
Lets see, are you getting faster on drinking or slower on working
Re: SLIDERS INSTALLED........................... [Re: Cab_Burge] #1588573
03/06/14 04:06 PM
03/06/14 04:06 PM
State of confusion
State of confusion
A little of both and it just seems that every time I work on the dart I end up w/a few beers in the fridge...............SPOOKY.......... Just got back from Pettis and Jason and Ellen said hi!
Re: SLIDERS INSTALLED........................... [Re: Thumperdart] #1588574
03/06/14 06:13 PM
03/06/14 06:13 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Good luck!
What slicks did u end up with?
Re: SLIDERS INSTALLED........................... [Re: FastmOp] #1588575
03/06/14 07:07 PM
03/06/14 07:07 PM
State of confusion
State of confusion
Thankxxx................I`ll get slicks after the rear end stuff is done and will probably get a 29x10.5 stiff wall something.
Re: SLIDERS INSTALLED........................... [Re: Thumperdart] #1588576
03/06/14 07:21 PM
03/06/14 07:21 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I don't see any sliders, probably just a dream while drinking
Re: SLIDERS INSTALLED........................... [Re: Quicktree] #1588577
03/06/14 07:44 PM
03/06/14 07:44 PM
State of confusion
State of confusion
Yep, It`s all a dream till it happens.................. Heading out now to finish painting stuff and will have pics Mon.
Re: SLIDERS INSTALLED..........UPDATE! [Re: Thumperdart] #1588578
06/04/14 12:04 AM
06/04/14 12:04 AM
State of confusion
State of confusion
Sliders kick azz............love em. Car`s way more stable and shoot and point and it goes. It`s really trying to hook up on the street but maybe next Sat. I can take care of a long over due street race and see what happens.............
Re: SLIDERS INSTALLED..........UPDATE! [Re: Thumperdart] #1588579
06/04/14 12:20 AM
06/04/14 12:20 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Any change in height?
Re: SLIDERS INSTALLED..........UPDATE! [Re: GY3] #1588580
06/04/14 12:28 AM
06/04/14 12:28 AM
State of confusion
State of confusion
Sorry, I fubared bringing this up by accident........... To answer your q, I accidently moved the ft. mounting point down about 3/4 of an inch but works like a charm so far street racing...........
