Re: SLIDERS INSTALLED...........................
[Re: Thumperdart]
#1588566
03/05/14 05:15 PM
03/05/14 05:15 PM
Posts: 52,968 Romeo MI
MR_P_BODY
I just checked em out and it seems after welding, the boxes have bowed out an 1/8 in. at the bottom causing a slight bind on the bearings so back to the grind....
Tack them good then run short hot welds about 1/2" to max 1"... let it cool before hitting the next spot
[Re: Thumperdart]
#1588567
03/05/14 05:18 PM
03/05/14 05:18 PM
Posts: 1,532 off the grid
340B5
off the grid
You'll like them. The rise is reduced quite a bit. I use never-sieze on the tracks once on a while on mine.
Yeah, it's got a smallblock.
[Re: Thumperdart]
#1588568
03/05/14 05:43 PM
03/05/14 05:43 PM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
Pull them together with a C clamp?
[Re: Thumperdart]
#1588570
03/05/14 07:36 PM
03/05/14 07:36 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I have a set of sliders that I bought from Alex Denysenko at www.moneymakerracing.net and I intend to use them on the Ramcharger. I have a large piece of square tubing that I will attach to the frame as a crossmember. The sliders will fit nicely on the bottom and the down tubes from the roll cage will attach at the top. I did the axle flip and have the Dana 60 above the springs with some long "Chevy" shackles and I don't like that (I don't think it is stable enough at the hit). I will post some pictures when I am done with it.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
Re: SLIDERS INSTALLED..........UPDATE!
[Re: GY3]
#1588580
06/04/14 12:28 AM
06/04/14 12:28 AM
Posts: 19,301 State of confusion
Thumperdart
State of confusion
Sorry, I fubared bringing this up by accident...........  To answer your q, I accidently moved the ft. mounting point down about 3/4 of an inch but works like a charm so far street racing...........
