Page 3 of 3 1 2 3
Re: life with an A12 hood? [Re: 68 HEMI GTS] #1588502
03/10/14 01:53 PM
03/10/14 01:53 PM
Detroit
Kidsixpack Offline
Kidsixpack  Offline
Detroit
I've never owned one of these cars but the topic prompted this question; I've seen a lot of original hoods that have what appear to be stress cracks around the scoop center support.
I assume, if you're pulling the hood by yourself, the only logical place to pick it up is through the scoop opening. Do most of you find that this causes the center of the hood to deflect and ends up causing the cracks? Just curious.
my hood was very broken and cracked when i got it. i added a little extra fiberglass in that area when i painted it.
yes this is common. It's cause from the air being sucked in as well as lifting the hood off from the top of the scoop. i always lift from the bottom of the scoop. I too reinforced the brace.
KID
Re: life with an A12 hood? [Re: Kidsixpack] #1588503
03/10/14 01:59 PM
03/10/14 01:59 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
I probably fixed 30 of these back in the day. Just spot-weld up a wide H alum or steel piece and glass-it-in there.
And BACK THEN ...I could have traded maybe 20 of those for a lite-weight piece ....using those OEM hoods as a 1/3 credit or so.
Re: life with an A12 hood? [Re: A12] #1588504
03/10/14 02:07 PM
03/10/14 02:07 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
The AAR and T/A hoods are great example of the perfect A12 hood.....but who wants an E-body with 3x2's and a small block
A few N94 equipped big block Challengers came with T/A hoods from the factory.
Re: life with an A12 hood? [Re: KillerBee] #1588505
03/10/14 07:09 PM
03/10/14 07:09 PM
Ohio
john55 Offline
john55  Offline
Ohio
The Plymouth Win You Over Beat Goes On
Re: life with an A12 hood? [Re: john55] #1588506
03/11/14 02:40 PM
03/11/14 02:40 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
I have only owned mine for a few weeks but it is kind of a pain. So far the pleasure from owning it has out weighed that.
And bonus ! No expensive hard to restore accurately with proper plating hood latch to pay for !
Page 3 of 3 1 2 3
