Page 1 of 3 1 2 3
life with an A12 hood? #1588462
03/05/14 01:54 PM
03/05/14 01:54 PM
the left coast
Hank Offline OP
Hank  Offline OP
the left coast
Hey A12 owners. Simple question: is living with an A12 hood a complete pain in the butt? Seems like anything from a oil change to a simple roadside repair would be complicated. And if you had to get to a problem under the hood quickly…? How do you deal with it?
Re: life with an A12 hood? [Re: Hank] #1588463
03/05/14 02:50 PM
03/05/14 02:50 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Well my car wasn't an a12, but had the hood and to me it was good and bad at times... not fun to remove the hood to check oil or something simple. However it was really nice at other times to not have a hood to hit my head on or hinges to avoid.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: life with an A12 hood? [Re: Silver70] #1588464
03/05/14 03:01 PM
03/05/14 03:01 PM
Detroit
Kidsixpack Offline
Kidsixpack  Offline
Detroit
I've owned my Bee for 21 years and have put a little over 32,000 miles on it. Yes the Hood is a pain in the azz. When you are planning to wrench it's not an issue, but all those little things like checking the oil or searching for an odd sound make it an issue. I very rarely remove the hood at cruise nights or small car shows. It's the most functional ram air system you can get! My sig. pic is prior to my 2005 resto.
KID
Re: life with an A12 hood? [Re: Hank] #1588465
03/05/14 04:37 PM
03/05/14 04:37 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Rob, good question but for the most part there were two main reasons the A12's got a hood with no hood hinges....and it was all a result of a personal reason by engineer Dick Maxwell and his engineering buddies. There's rumor, folklore or whatever you want to term it that there was a rush to production for '69 when the 440+6 was really supposed to be a 1970 model year car and not a '69-1/2 "package". Rumor had it that the test mule 440 6bbl GTX was spotted at a Woodward hangout by some GM people in the Fall of '68. So in order to get the 3x2 440 out there they scrambled for parts and that meant getting a non-inhouse company to make an intake manifold (Edelbrock) and a hood that would feed more air than the '69 hood. The situation with the Edelbrock 3x2 ALUMINUM manifold bears out as to this day it is considered a better intake than the '70+ cast iron (some will say not but who is making a CAST IRON intake that anyone is BUYING ). Being better and not using it for '70+ models was because Chrysler only needed a temporay supply for '69-1/2 production. The LOH on the '69 A12's is the only mass PRODUCTION car that I know of that didn't have hood hinges or a way of mechanically (cable, lever, etc) or by vacuum closing off the outside fresh air access.
So the rush to production for mid year '69 had a lot to do with the A12 "package" and the second or best reason was that Dick Maxwell told me "Mike this was the last BADAZZ street car we were ever going to be able to build". And what better thing to do for a race car but to have a light weight fiberglass hood that could be lifted off and moved out of the way to tune between runs and to cool down the engine as best as possible. The hood was for a purpose or purposes; tuning, cooling, weight savings, ram air. Note that the scoop opening is above the hood surface as the intake air into the scoop moves faster than the "boundry layer" air close to the hood's surface.
It was a race inspired hood that somehow got into production and Dick Maxwell and another two engineers even "hosed down" the hood with GARDEN HOSES to prove to upper management that the A12 could survive and not shut down in a heavy rain or down pour That is right from Dick Maxwell
For the few that suffered and still suffer many took advantage of the LIFT-OFF-RACE-HOOD on the LAST BADAZS STREET CAR and the poster child of the musclecar era
Re: life with an A12 hood? [Re: Kidsixpack] #1588466
03/05/14 04:39 PM
03/05/14 04:39 PM
the left coast
Hank Offline OP
Hank  Offline OP
the left coast
Great info guys. How much does the hood weigh and what is the technique for one person to remove it?
Re: life with an A12 hood? [Re: Kidsixpack] #1588467
03/05/14 04:40 PM
03/05/14 04:40 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Removing the hood by yourself is relatively easy, unless it's windy! Grab it inside the scoop next to the center support and put your hip into the front center, lift up and away you go. I have never had any issues on my own. What you do gain is the ease of working on the engine bay w/o worrying about hitting you head on the hood!!!
Admiration For Multiple Carburetor Vehicles...
Re: life with an A12 hood? [Re: Stewpar] #1588468
03/05/14 05:44 PM
03/05/14 05:44 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I made clear 1" dia. stanchions with hood pins to set the hood on whenever I needed to work on it. helped alot by not finding a place to set the hood or scratch it across the roof.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: life with an A12 hood? [Re: 6PKRTSE] #1588469
03/05/14 06:05 PM
03/05/14 06:05 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Whatever small issues there are its worth it...Coolest option ever..
Anyway...
Taller guys have an advantage ..Im short so it is a bit of a PITA, I dont own an A12 but have worked on dozens of them...One thing that every A12 owner should own is a folding tubular stand like the bodyshops use...Put some foam on it so it doesnt damage the hood...I dont like putting the hood on the roof...Ive heard of hoods falling down off the roof-yes, even with the vinyl top...
MB
Re: life with an A12 hood? [Re: HPMike] #1588470
03/05/14 07:29 PM
03/05/14 07:29 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
When the hood is off, wind is your worst enemy. I don't own an A12 but I did have a 'glass liftoff hood and I usually sat it flat on the ground for just that reason. I had hood pins mounted to my shop wall so I could hang the hood when I was working on the car.
Re: life with an A12 hood? [Re: Stewpar] #1588471
03/05/14 08:31 PM
03/05/14 08:31 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Removing the hood by yourself is relatively easy, unless it's windy! Grab it inside the scoop next to the center support and put your hip into the front center, lift up and away you go. I have never had any issues on my own. What you do gain is the ease of working on the engine bay w/o worrying about hitting you hear on the hood!!!
That's how I did it back in 1976 and I only weighed 110 pounds soaking wet
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: life with an A12 hood? [Re: AZ_A12_BEE] #1588472
03/05/14 11:17 PM
03/05/14 11:17 PM
Washington state
pinkmeepmeep Offline
Washington state
Call me, well... call me whatever you want, but I loved pulling the hood off of my a12 superbee. Liken it unto a ritual that few ever get to experience. It always initiated a conversation, and an opportunity to meet people. An avenue by which the minions could catch a glimpse of how truly unique and awesome these machines really are. An opportunity to enlighten the uneducated, and share in the beauty. We know all about these cars, and in some sense we can become almost desensitized, or callous as to just how over the top they are. Many people have never even seen or heard of one of these cars! It is exciting to be able to see that "light" come on in someone's eyes for the first time. I think of taking the hood off as an "event", an unveiling, so to speak. I remember pulling into a gas station and it was like, "showtime". I am a left handed artist, and musician so that's how I roll. That being said, I was always worried about wind, and concerned about damage occurring to the hood when it was off. For what its worth... Just one more opportunity to admire that sexy thing. If it weren't for 9/11, I would still have mine. God bless
Re: life with an A12 hood? [Re: pinkmeepmeep] #1588473
03/05/14 11:33 PM
03/05/14 11:33 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Re: life with an A12 hood? [Re: Hank] #1588474
03/05/14 11:40 PM
03/05/14 11:40 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Oh the stories those hoods could tell.....
My original A12 hood was supposedly victim of the "Oh $#!T I forgot to re-pin the hood" and run over by a Chevelle that was getting beat by the A12 (Gary Tsuperbee you have to back me on that one) and then there's the story of someone's wife driving the husband's A12 to the gas station back in the day when they pumped the gas, cleaned your windshield AND checked your oil.......yep pulled only the front two hood pin clips out and tried to open it with the rear two pins still in .
Okay we need some more...A12 sail hood stories
Re: life with an A12 hood? [Re: A12] #1588475
03/06/14 12:10 AM
03/06/14 12:10 AM
At Your Plymouth Dealers
*440-6BBL* Offline
super gas
*440-6BBL*  Offline
super gas
Al Kirschenbaum with the first A12 Road Runner built ...testing for Cars Magazine...April 1969 - looks like he's got the right idea....
.....other than maybe he's thinking "Now where am I going to put it..?"
Re: life with an A12 hood? [Re: A12] #1588476
03/06/14 12:47 AM
03/06/14 12:47 AM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
It's not really much of a pain. I always get help putting it on the roof. In 40+ years, I only had to worry about the wind once at a car show. You don't need to take it off that often and you can always get help. Mine flew off my old black car twice. Once on the trailer on my way to the races. After I loaded it up, I disconnected the battery and walked around behind the trailer and forgot to put the pins in. It blew off about 800' down the road. It was 4 lanes and a car behind me stopped and moved it to the shoulder. I was lucky to realize it almost as soon as it happened. I had to walk back and get it and carry it myself about 800' and put it back on the car on the trailer! It only weighs about 37 lbs but that was tough duty to carry it that far on a 95 degree sunny day! It cost me $40 to get a friend to fix both corners and repaint it back gloss black. Nice to have such friends!
The second time was leaving the scales at Maple Grove after weighing in after winning a big race. I had to get in the engine compartment after I weighed it and the cars were lining up behind me. I took iff in a hurry and it flew up about 30' landed on the tip of my deck lid almost right above the trunk lock and ended up flat on the pavement behind me without hurting the hood! I did some paintless dent repair on the decklid before that technique became a craft. The car still had a ding on it that I couldn't get out when I sold the car in 1995. I would not trade my lift off hood for anything!
Re: life with an A12 hood? [Re: RoadRunnerJD] #1588477
03/06/14 02:27 AM
03/06/14 02:27 AM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
I would put mine under the back of the car if the wind came up
NS1AAR
Re: life with an A12 hood? [Re: ns1aar] #1588478
03/06/14 02:52 AM
03/06/14 02:52 AM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Not a real A12, but I've had mine for years on a street car with no issues. Just learn to find a good spot on the ground.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: life with an A12 hood? [Re: AlexP] #1588479
03/06/14 07:11 AM
03/06/14 07:11 AM
Ohio
dobie Offline
dobie  Offline
Ohio
My car obviously isnt an A12 car..('68 RR), but I've had a lift off hood since Ive ben driving it.
Its a pain in the butt for routine things, like checking oil, connecting battery cables, and even in the garage since my space is limited. Over the last couple of years Ive been fighting a wiring issue as well. After shutting it off, sometimes the car has no power at all, anywhere, and I have to jiggle the bulkhead wiring to make the connection. At a gas station, finding a place for the hood can be a pain.
With all of that however, Im still very happy with my set up. These fiberglass hoods are fairly lightweight and its relatively easy for me to remove/replace by myself. On the occasions when Im actually working on something, its fantastic to be able to have an unobstructed work area underneath the "hood."
Oh, and I agree that its just plain "badazz" having that huge, functional scoop that looks so cool. It's definitely something that drew me into this hobby.
1968 Plymouth Road Runner 383 4 speed
Re: life with an A12 hood? [Re: dobie] #1588480
03/06/14 01:01 PM
03/06/14 01:01 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Eh...if you have ever gotten your skull impaled on the typical E/B body secondary hood catch hook, then you will be thankful you have a liftoff...
MB
Re: life with an A12 hood? [Re: HPMike] #1588481
03/06/14 01:21 PM
03/06/14 01:21 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
MB
Ha! I just sold my A12 Bee and now have a '70 Bee, and wouldn't you know it, I have just about drawn blood twice already with that @#%&*@ meat hook on the hood!!!
Page 1 of 3 1 2 3
