Dual quad or dual 4 bbl 440 intake #1588383
03/05/14 10:14 AM
03/05/14 10:14 AM
west palm beach, florida
modelmakerinc Offline OP
Guys, For a 440 I know of the edelbrock lowrise dual quad intake (5440) but I am not a fan of eddy carbs is there an intake like it for holleys, or can/will adapters need to be used.
part numbers and links would be helpful
thanks in advance Henry
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Dual quad or dual 4 bbl 440 intake [Re: modelmakerinc] #1588384
03/05/14 10:31 AM
03/05/14 10:31 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
WHat makes you think a Holley can't be used?
Don't be the exception.
Re: Dual quad or dual 4 bbl 440 intake [Re: Supercuda] #1588385
03/05/14 10:35 AM
03/05/14 10:35 AM
Because the bolt pattern is for afb/ eddy style carbs. Even the ads are clear: Note: Requires the use of Edelbrock, or Carter AFB style carburetors.
That's why I asked if/can adapters be used
Chrysler, Big Block
Designed for 413-426-440 c.i.d. Chrysler V8s.Note: Requires the use of Edelbrock, or Carter AFB style carburetors.
Re: Dual quad or dual 4 bbl 440 intake [Re: modelmakerinc] #1588386
03/05/14 11:11 AM
03/05/14 11:11 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I think the Offenhauser 5206 will let you use holleys.
Coming soon!!!!
Re: Dual quad or dual 4 bbl 440 intake [Re: Mr.Yuck] #1588387
03/05/14 12:30 PM
03/05/14 12:30 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
A VERY low performance intake if I remember my dyno results though, the Edelbrock intake and just about any single four barrel intake spanks it.
http://www.hotrod.com/techarticles/hrdp_0712_mopar_intake_manifold_comparo/viewall.html
"I think its got a hemi"
Re: Dual quad or dual 4 bbl 440 intake [Re: gdonovan] #1588388
03/05/14 12:49 PM
03/05/14 12:49 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
then he'll have to look on e-bay for something else.
Re: Dual quad or dual 4 bbl 440 intake [Re: modelmakerinc] #1588389
03/05/14 01:49 PM
03/05/14 01:49 PM
dogdays Offline
dogdays  Offline
I believe the problem using Holleys is that the fuel bowls interfere with each other. So unless you turn them sideways they won't fit.
The "two AFBs on an intake" look is very old school Chrysler, don't see why you don't want that. As for tuning, I don't remember any OEM inline two-fours intakes that used Holleys, back in the day.
R.
I'm sure someone will refresh my memory!
Re: Dual quad or dual 4 bbl 440 intake [Re: modelmakerinc] #1588390
03/05/14 01:58 PM
03/05/14 01:58 PM
League City, TX
BlueGhost Offline
BlueGhost  Offline
League City, TX
The Indy Mod Man intake looks like it would have enough room for Holley carbs, you may have to modify or make your own top plate for them to fit.
1958 Plymouth Suburban
Re: Dual quad or dual 4 bbl 440 intake [Re: BlueGhost] #1588391
03/05/14 02:51 PM
03/05/14 02:51 PM
central illinois
65dodgebob Offline
65dodgebob  Offline
central illinois
I just purchased a mod man intake for 440 with 2 four barrel top, and I can tell you 2 holleys will not fit. I tried it. You would have to change bolt pattern on the top plate. Possible could use some sort of adapters, but you would be better off with Eddy's or afbs.
Re: Dual quad or dual 4 bbl 440 intake [Re: 65dodgebob] #1588392
03/05/14 03:18 PM
03/05/14 03:18 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
You could go to a pair of Street Demon carburetors on the CH440.
Keith
Re: Dual quad or dual 4 bbl 440 intake [Re: modelmakerinc] #1588393
03/05/14 04:11 PM
03/05/14 04:11 PM
Can you post a picture of that intake? I hope so, I think that manifold may be a duplicate of the original stock OEM cast iron Mopar intakes If so those where a single plane style intake, I've ran those and they where not the best out there They did work better with one to one linkage instead of progressive Good luck, maybe a 2x4 tunnel ram would be better
Re: Dual quad or dual 4 bbl 440 intake [Re: Cab_Burge] #1588394
03/05/14 05:51 PM
03/05/14 05:51 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the spacing on the edelbrock ch28 is too close for holleys. the demon google valve carb might fit. the edelbrock/afb carbs should be trouble free easy carbs,.... . this is what i'm doing. the ch28 isn't a "low rise" intake.
Re: Dual quad or dual 4 bbl 440 intake [Re: Mr.Yuck] #1588395
03/05/14 06:45 PM
03/05/14 06:45 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
I thought it would too but I looked it up. It will not.
I’m listening.
Re: Dual quad or dual 4 bbl 440 intake [Re: dogdays] #1588396
03/05/14 08:06 PM
03/05/14 08:06 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
R.
Some 427 Fords ran inline Holley's.
Re: Dual quad or dual 4 bbl 440 intake [Re: modelmakerinc] #1588397
03/05/14 08:20 PM
03/05/14 08:20 PM
here's a pic of my early 60's iron single plane with a pair of 4131 AFB's going on a 451. Not a killer setup more of a toy to play with.
Re: Dual quad or dual 4 bbl 440 intake [Re: RapidRobert] #1588398
03/05/14 09:26 PM
03/05/14 09:26 PM
well, I guess since trying to use a pair of holleys I have will not an easy scenario. I will look into buying the edelbrock intake and carbs. summit has a combo with everything needed for $1200
Or I may look into doing a procharger set-up. ever since I took off the tunnel ram, all my friends tell me I should keep the hood on.
The Fury is lacking a little bling or wow factor under the hood.
Then
NOW
Re: Dual quad or dual 4 bbl 440 intake [Re: gdonovan] #1588399
03/05/14 10:22 PM
03/05/14 10:22 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Everyone trots that out as if it were some sort of valid test, but they were too cheap and/or lazy to get a couple of strip kits to calibrate the carbs, they said the engine was running 10.9:1 a/f ratio, i.e. way too rich. If Offy was spending AD money with that rag, you can bet it wouldn't have even been included without a re-jetting. To the OP, the low Offy manifold can only run Holleys sideways NOT inline.
Re: Dual quad or dual 4 bbl 440 intake [Re: Skeptic] #1588400
03/05/14 10:28 PM
03/05/14 10:28 PM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
I believe this is not so...I have owned one for over 30 years, holleys DO fit normally (F to R), and 2 600s work nicely OOTB.
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
Re: Dual quad or dual 4 bbl 440 intake [Re: Skeptic] #1588401
03/05/14 10:29 PM
03/05/14 10:29 PM
Indiana
maxie Offline
maxie  Offline
Indiana
there is a offenhouser 440 intake with dual fours already on it on the muncie indiana craigslist
Re: Dual quad or dual 4 bbl 440 intake [Re: maxie] #1588402
03/05/14 10:47 PM
03/05/14 10:47 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
I've got a low deck deck version here right now and there is NO way a pair of Holley carbs will fit inline
