Re: Dual quad or dual 4 bbl 440 intake [Re: Skeptic] #1588403
03/05/14 11:53 PM
03/05/14 11:53 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Everyone trots that out as if it were some sort of valid test, but they were too cheap and/or lazy to get a couple of strip kits to calibrate the carbs, they said the engine was running 10.9:1 a/f ratio, i.e. way too rich.
I have one on the rack and have run it, looking to buy one?
Edelbrock TM with a TQ spanks its rear pretty hard, did on my ride.
This intake is good for a cruiser, all I'd use it for. Any decent single four will make more power and be less trouble.
"I think its got a hemi"
Re: Dual quad or dual 4 bbl 440 intake [Re: gdonovan] #1588404
03/05/14 11:56 PM
03/05/14 11:56 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Edelbrock TM with a TQ spanks its rear pretty hard, did one my ride.
Don't need another one- see my above post, I bought mine for a blower project that has gone by the wayside. I never said it was a great manifold, but that "test" was crap.
Re: Dual quad or dual 4 bbl 440 intake [Re: Skeptic] #1588405
03/06/14 12:08 AM
03/06/14 12:08 AM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
OK,I see what you see, remember the 600s only have 1 metering block and a short bowl.My offy is 70s and has removable carb flanges with a dual BP, it is for an RB.maybe they changed it?
Re: Dual quad or dual 4 bbl 440 intake [Re: Skeptic] #1588406
03/06/14 12:37 AM
03/06/14 12:37 AM
Cab_Burge Online work
Cab_Burge  Online Work
I've got a low deck deck version here right now and there is NO way a pair of Holley carbs will fit inline
That is the Offy dual quad intake that acts and looks like a single plane intake withe a divider down the middle, none of those type intakes I have work on or drove work very well with progressive carb. linkage One to one carb. linkage did help but still a little lazy down low, under 2500 RPM I haven't treid any of the new Eddy 2x4 in line dual plane looking intakes, they may be better
Re: Dual quad or dual 4 bbl 440 intake [Re: Sixgun] #1588407
03/06/14 12:43 AM
03/06/14 12:43 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
OK cool, I've got the spacers around here somewhere, but they don't have any offset on the center->center. I'll take your word the 600s will fit inline. I've wondered if they would work better with a pair of spacers. Here's a shot of the Offy manifold that ended up in the car- still a work in progress. It made 472 hp, 489 ft/lbs with a small Thumper cam and mildly ported RPM heads on a 9.8:1 .030 over stock stroke 400. That was just getting a basic tune on the dyno.
Re: Dual quad or dual 4 bbl 440 intake [Re: Skeptic] #1588408
03/06/14 01:09 PM
03/06/14 01:09 PM
dogdays Offline
dogdays  Offline
You are showing a center pivot float Model 4150 carb. The side pivot float fuel bowls are much shorter, plus the 4160 doesn't have a secondary metering block. Your picture proves nothing.
R.
