77 Cordoba Disk Brakes fit on a 70 RR without problems
#1587393
03/03/14 02:20 PM
03/03/14 02:20 PM
Posts: 1,562 Manistee, Michigan.
High Impact
Manistee, Michigan.
I have a set of disk brake's (spindle's and all) that I saved off a 77 Cordoba that I parted out last year. Can I use them on my 70 Roadrunner? I wondered if the ball joints will bolt right up to these assemblys. The runner has drums. Thanks! ![](/ubbthreads/images/graemlins/2241092-prplchrgr.gif)
Re: 77 Cordoba Disk Brakes fit on a 70 RR without problems
[Re: High Impact]
#1587394
03/03/14 02:53 PM
03/03/14 02:53 PM
Posts: 801 central CT
cudazappa
central CT
Yes.
The spindles will bolt right up. Mount the calipers to the front like the 70-72 B bodies and you'll just need to source the appropriate flex hoses.
1971 Challenger
[Re: cudazappa]
#1587395
03/03/14 03:01 PM
03/03/14 03:01 PM
Posts: 5,366 Rancho Cordova, California (Sa...
hemi71x
If you don't allready have 15 inch wheels you will need them. Those Cordoba's use 11 3/4 inch rotors, so you need 15's to clear the calipers. Something for you to think about.
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: 70_FJ6_RR]
#1587397
03/03/14 04:03 PM
03/03/14 04:03 PM
cudazappa
central CT
75-83
76-79 'dobas have 11.75" rotors (continued use from 79-81 in R-bodies) 75 & 80-83 'dobas have 10.87" rotors
1971 Challenger
[Re: 70_FJ6_RR]
#1587398
03/03/14 08:21 PM
03/03/14 08:21 PM
Posts: 415 Indiana
Pentastar440
Indiana
I have '79 Cordoba discs on my '65 Belvedere .
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
[Re: ZWM300]
#1587401
03/31/14 09:54 AM
03/31/14 09:54 AM
Posts: 21,084 Niles , Ohio
therocks
Niles , Ohio
Drum spindles are totally different than disc.I run a 5th Ave PP valve on my 65.The Doba spindles are IIRC taller than the RRs.Mine are taller than the 65s.Been on at least 10 years now.I had Dart spindles and changed to the taller ones.Pin calipers you can get ceramic pads for them.I run the ceramics on my 65.No fade ever and stops great.Rocky
Chrysler Firepower
