440 6 pack 22 rad fan?
#1586964
03/02/14 12:48 PM
03/02/14 12:48 PM
Posts: 1,723 Nebraska
70VcodeCoronetRT
Nebraska
Hello, can anyone tell me the correct part number for the fan for a 70 b body 440 6 pack with the 22 radiator? Any pics of a 22 inch setup? Thanks in advance.
Re: 440 6 pack 22 rad fan?
[Re: FC7cuda]
#1586966
03/02/14 01:28 PM
03/02/14 01:28 PM
70VcodeCoronetRT
Nebraska
Thanks! if only I could read that part number Thanks again
[Re: m46rat]
#1586968
03/02/14 02:36 PM
03/02/14 02:36 PM
70VcodeCoronetRT
Nebraska
That part number comes up as the shroud. I;m looking for the fan itself. Thanks though
[Re: FC7cuda]
#1586969
03/02/14 02:52 PM
03/02/14 02:52 PM
Posts: 6,585 SE Pa.
LimeliteAero
SE Pa.
survivor pic
orange plug wires and GM hose clamps on both hoses? Not a survivor to me. who knows whats been replaced?
[Re: FC7cuda]
#1586975
03/03/14 01:01 AM
03/03/14 01:01 AM
Posts: 315 Ontario, Canada
RealWing
Ontario, Canada
2863 224 7-blade fixed fan & 1851 959 fan spacer 1.06" lg
Dan,
My fan is "60" and spacer "16".
Tom
The parts book shows the 2863224 as an 18" "standard cooling" fan for a 318, 360, 383, & 440. The "High capacity" fan is 2863223 for a 383, 440.
The 1.06" spacer is p/n 1851223 ( a p/n 2003059 spacer is used on a 383/440 with AC.
I don't see a "60" fan or a "16" spacer in the parts book. If anyone has their Broadcast sheet, both the fan and spacer are coded on it with the last 2 digits of the part number.
1970 Superbird 440-6bbl, auto 1969 Barracuda 340-4bbl, FB Formula S auto 1969 Barracuda 6.1 L Hemi, 5 speed, Convertible 2022 Can Am Spyder RTL
[Re: FC7cuda]
#1586977
03/03/14 02:02 AM
03/03/14 02:02 AM
Posts: 17,547 Las Vegas, NV
6bblgt
Las Vegas, NV
Tom
That a '70 car with a '69 b'cast. 60 is the radiator "2998960"
This info is from a '70 Coronet R/T b'cast 440 4bbl - auto - 3.23s
E-bodies & the 6bbl Fury GTs are "24" & "10" - 2863 224 & 2120 510 1.60" lg. (I guess there's a little more room under the hood).
[Re: FC7cuda]
#1586979
03/03/14 12:54 PM
03/03/14 12:54 PM
Posts: 1,652 Calgary, Alberta Canada
m46rat
Dan,
Tom
Tom: Check your broadcast sheet, I think your sheet is a 1969 sheet with 1970 codes imprinted onto it. This happens on a lot of 1970 early production cars. The 72 to the right of the 60 and 16 would normally be the alternator code. Everything on your sheet is shifted, which happens when your sheet is one from 1969.
