Re: 340 head cc
[Re: GKMOPAR]
#1586823
03/02/14 02:55 AM
03/02/14 02:55 AM
RapidRobert
Speedway motors has a CC kit for real cheap. Can slightly deburr the chambers till they're equal (to the largest one of course) then mill em as needed keeping in mind SCR/vp clearance. Best would be to also mill the open chamber areas (get em flat/same depth) then get .040" piston/head quench. $$$ but worth it if set on using OE open chambered iron heads. Unshrouding at the outer end of the intake/ex valves to add the CC's works the best for flow.
