Re: Roller rocker spacing?
[Re: EvilScamp]
#1586725
03/01/14 11:34 PM
03/01/14 11:34 PM
RapidRobert
I'd wanna get down to .015" now/with good side to side alignment on the shaft. Somebody has em
[Re: Cab_Burge]
#1586729
03/02/14 01:56 AM
03/02/14 01:56 AM
Posts: 5,445 So Cal
Sinitro
So Cal
As Cab said, getting the proper alignment of the roller tip to the valve stem is the challenge... To accomplish this we do the following: 1. Use a spare head for as a mockup sample 2. Use a Dremel tool/sanding drum to modify the valve shim for the proper clearance.. For example, if U need a shim of 0.012, take a 0.015 shim and sand it down slightly 3. After setting the rockers and shims up, mount the shaft on the mockup head. Torque down the shaft, now recheck the rocker clearances they can change slightly. This procedure allows one to optimize the rocker setup easily, and then transfers the total shaft/rockers/shims for final engine mounting. Just my $0.05...
[Re: EvilScamp]
#1586733
03/03/14 06:07 PM
03/03/14 06:07 PM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
I'm using .015 now, does anyone make any thinner shims? Neither Summit or Jeg's carry them.
Check Mancini and or Hughes for the shims . Springs are ok on ductile rockers ... well for some maybe ... I wouldn't use them on alum. body rockers if that's what you have. If you go with springs you'll want to put a shim between it and the rocker body and you still need to shim it to center the roller tip over the spring , you can't use a spring between the rocker and the stand .
[Re: JohnRR]
#1586734
03/03/14 07:32 PM
03/03/14 07:32 PM
Posts: 8,896 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
No problem on ANY ductile rocker. But you still want a shim an either side of the rocker to prevent wear from both the spring and the stand.
Why not, aluminum or iron - makes no difference. Shim between the spring and rocker to prevent wear.
Absolutely.
Really, did this need to be stated ?!?!?!?
[Re: Stanton]
#1586735
03/03/14 11:58 PM
03/03/14 11:58 PM
JohnRR
U.S.S.A.
Obviously it did because you found the need to completely dissect my post ...
the thick heavy springs cause friction side loading against the rockers and the light springs could allow the rockers to shift sideways when opening the valve.
The spring is a crutch for people too lazy to use spacers ...
[Re: JohnRR]
#1586736
03/04/14 12:25 AM
03/04/14 12:25 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Hmmm, tell that to Tom Hoover !!!
[Re: Sinitro]
#1586740
03/04/14 04:36 PM
03/04/14 04:36 PM
Posts: 43,252 Bend,OR USA
Cab_Burge
Just my $0.05...
No disrespect intentded, I wouldn't swap rocker assemblys from side to side once their set up, let alone set them up on another head and then expect them to be correct for a head that may be a different brand or casting number OP, my message is to set up the rockers for the heads your going to run and mark the assembly in a way you know which rockers go on which head Setting them up can be very challenging, I start with the two inner cylinders and then do one outer at a time, not much fun anyway you do it but it does help make the motor more efficient and the parts will last longer when done properly I need to clarify once you get the roller tip so it is in full contact with the valve stem moving it so it is centered is not a gain in performance or longivity, it just looks better In other words if you can't get it centered on any or all of them don'tworry about it, as long as the roller tip is in full contact
