Page 9 of 18 1 2 7 8 9 10 11 17 18
Re: Scratch Built Willys MB [Re: Defbob] #1586113
01/25/15 03:35 PM
01/25/15 03:35 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
without the weight of the drivetrain, it has 21" under it
Re: Scratch Built Willys MB [Re: Defbob] #1586114
01/31/15 07:26 PM
01/31/15 07:26 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
I cut a hole
Re: Scratch Built Willys MB [Re: Defbob] #1586115
01/31/15 07:27 PM
01/31/15 07:27 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
I fill the hole
Re: Scratch Built Willys MB [Re: Defbob] #1586116
01/31/15 07:28 PM
01/31/15 07:28 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Now I can get the correct angles for the drivetrain
Re: Scratch Built Willys MB [Re: Defbob] #1586117
01/31/15 07:29 PM
01/31/15 07:29 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Atlas says hi
Re: Scratch Built Willys MB [Re: Defbob] #1586118
01/31/15 07:30 PM
01/31/15 07:30 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
By moving the drivetrain to the passenger side 1", I have room for everything
Re: Scratch Built Willys MB [Re: Defbob] #1586119
01/31/15 07:31 PM
01/31/15 07:31 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
I tack welded the skid plate in place so I can drill the holes for the mounts
Re: Scratch Built Willys MB [Re: Defbob] #1586120
01/31/15 07:32 PM
01/31/15 07:32 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
The Atlas poking out for a look
Re: Scratch Built Willys MB [Re: Defbob] #1586121
02/07/15 08:01 PM
02/07/15 08:01 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
K-member/skid plate mount
Re: Scratch Built Willys MB [Re: Defbob] #1586122
02/07/15 08:02 PM
02/07/15 08:02 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
motor mounts tack welded
Re: Scratch Built Willys MB [Re: Defbob] #1586123
02/07/15 08:03 PM
02/07/15 08:03 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Chassis only settled 1/2" from the weight
Re: Scratch Built Willys MB [Re: Defbob] #1586124
02/07/15 08:04 PM
02/07/15 08:04 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
k-member offset to cleat the pinion and match the offset of the tranny pan. The t-case skid has the same offset.
Re: Scratch Built Willys MB [Re: Defbob] #1586125
02/07/15 08:05 PM
02/07/15 08:05 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Mounted the shifters to build the new tranny hump around them.
Re: Scratch Built Willys MB [Re: Defbob] #1586126
02/07/15 08:06 PM
02/07/15 08:06 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
first piece is made
Re: Scratch Built Willys MB [Re: Defbob] #1586127
02/07/15 08:06 PM
02/07/15 08:06 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
and the matching lid
Re: Scratch Built Willys MB [Re: Defbob] #1586128
02/08/15 02:01 PM
02/08/15 02:01 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
Very nice work. Thanks for taking the time to show us the progress!
Re: Scratch Built Willys MB [Re: 440newport] #1586129
02/08/15 06:05 PM
02/08/15 06:05 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
making patches
Re: Scratch Built Willys MB [Re: Defbob] #1586130
02/08/15 06:05 PM
02/08/15 06:05 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
and lids
Re: Scratch Built Willys MB [Re: Defbob] #1586131
02/08/15 06:06 PM
02/08/15 06:06 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
I still need to make a box around the shifters for the boots.
Re: Scratch Built Willys MB [Re: Defbob] #1586132
02/14/15 04:40 PM
02/14/15 04:40 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
'07 waterpump and 145amp alternator mounted
