Vacuum Line Confusion, 71 Charger w /A/C #1585873
03/01/14 03:56 AM
03/01/14 03:56 AM
Upstate New York
archie340 Offline OP
Upstate New York
In the process of completing the installation of my heater box for my 71. I have made all the connections at the box but am trying to figure out where the green hose connects in the engine compartment. Maybe between the water valve and engine vacuum source? Unfortunately for me the lines were disconnected a long time ago. If anyone whould happen to have a diagram or be willing to trace the line for me, I would be most appreciative!
Re: Vacuum Line Confusion, 71 Charger w /A/C [Re: archie340] #1585874
03/01/14 05:23 AM
03/01/14 05:23 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The green hose usually goes to the recirculation door. But I am not sure where it is on your car as most are inside the car. I might be able to try and find the vacum hose routing for the AC system in one of my books. Ron
Re: Vacuum Line Confusion, 71 Charger w /A/C [Re: archie340] #1585875
03/01/14 11:54 AM
03/01/14 11:54 AM
MarkMcDonald Offline
Look under the battery tray for a vacuum can.
Re: Vacuum Line Confusion, 71 Charger w /A/C [Re: archie340] #1585876
03/01/14 02:33 PM
03/01/14 02:33 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
I don't have a '71 Dodge FSM but here is a page from the '71 Plymouth one. Perhaps it will help. The FSM shows the vacuum tank/reservoir under the battery (as already mentioned above).
Re: Vacuum Line Confusion, 71 Charger w /A/C [Re: archie340] #1585877
03/01/14 03:46 PM
03/01/14 03:46 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Don't see any green referenced lines in the above pic....Look in your 71 dodge FSM...That will have all the info...
