good to hear!
on a side note, i went through two of those pumps, supposed to be regulated for the carter carbs. first was 10+lbs of pressure constantly. found that hard to believe, so i used a second test gauge, exactly the same thing. mancini replaced it, and the second was better, sort of… it didn't hang out at 10 all the time, and did spend much of its time down at 5-6, but would jump up to 9, 10, and then go back down. sometimes. it wasn't predictable, at least for the time i was monitoring it.
