E body transmission crossmember difference
#1585168
02/27/14 09:17 PM
02/27/14 09:17 PM
Posts: 1,184 clarks summit pa
73cuda340
clarks summit pa
I just installed the 4 speed transmission crossmember in my cuda and only the center two bolt holes line up and the outer two holes are about an inch or so from lining up. I believe that I have a 70 crossmember and need a 71-74 style. Does anybody have any pictures of the two or even better, the measurement of the bolt holes for each? Thanks
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
