Page 1 of 3 1 2 3
Aluminum heads and spark plugs #1583795
02/24/14 09:21 PM
02/24/14 09:21 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Any down sides to using anti-seize on the spark plug threads on aluminum heads?
Fastest 300
Re: Aluminum heads and spark plugs [Re: Crizila] #1583796
02/24/14 09:36 PM
02/24/14 09:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have done it in the past... just get it on the threads
so it can ground via the compression washer... it
still has to ground... the only reason I did it on
that engine was the threads in the heads were a bit
messed up(I chased them but they were still weird)
Re: Aluminum heads and spark plugs [Re: Crizila] #1583797
02/24/14 10:01 PM
02/24/14 10:01 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I use anti seize on my plugs and also on vehicles at work.As Mr P. said,threads only and you only need a very light coat.
Nautilus Racing-
Re: Aluminum heads and spark plugs [Re: MR_P_BODY] #1583798
02/24/14 10:12 PM
02/24/14 10:12 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
If there are any downsides I have never experienced them
Re: Aluminum heads and spark plugs [Re: roadhazard] #1583799
02/24/14 11:14 PM
02/24/14 11:14 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree a small bit on the threads.Ive done thousands at work and do it on mine.I even use it on iron heads.I loved customers who thought you could go over 100K and years on a set of factory plugs.I had one that had over 230K on OE set.Came in as a no run.Pulled plugs and most of the plug was gone.That and antisieze makes them come out easy next time.Rocky
Chrysler Firepower
Re: Aluminum heads and spark plugs [Re: MR_P_BODY] #1583800
02/24/14 11:19 PM
02/24/14 11:19 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
That was exactly what I was getting to - the ground issue. Thanks Cab.
Fastest 300
Re: Aluminum heads and spark plugs [Re: Crizila] #1583801
02/25/14 02:07 AM
02/25/14 02:07 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I don't know if it matters but I would use the hi temp copper stuff just so I could sleep at night.
Kevin
Re: Aluminum heads and spark plugs [Re: Twostick] #1583802
02/25/14 02:48 AM
02/25/14 02:48 AM
Cab_Burge Online work
Cab_Burge  Online Work
I use the Champion brand of aircraft liquid graphite spark plug anti seize
Re: Aluminum heads and spark plugs [Re: Cab_Burge] #1583803
02/25/14 04:30 AM
02/25/14 04:30 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I just put a small dab on a few threads and let the tightening spread it out. For something that gets frequent plug changes (race motors) I haven't seen a need to do it every time, maybe every other or every 3rd set, as a sufficient amount appears to remain on the threads in the heads.
Re: Aluminum heads and spark plugs [Re: Crizila] #1583804
02/25/14 11:32 AM
02/25/14 11:32 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
MSD advised us not to use it on our spark plugs while using there 44 amp mags on our top alcohol engines. It has a lot of resistance and can cause misfires. They also advised us to ground each head separately to insure proper grounding with aluminum heads.
For a race car that get's it's plugs changed often a drop of oil is better.
Re: Aluminum heads and spark plugs [Re: Challenger 1] #1583805
02/25/14 12:06 PM
02/25/14 12:06 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
MSD advised us not to use it on our park plugs while using there 44 amp mags on our top alcohol engines. It has a lot of resistance and can cause misfires. They also advised us to ground each head separately to insure proper grounding with aluminum heads.
Been having some misfire issues above 5K. I think I used too much anti-seize on the plugs. When I pulled them to put in a fresh set, had lots of it in the plug gasket seat area. Wiped the seat area down and put the new plugs in with just a drop of oil. Misfire was gone. I have one head grounded. Will do the other. Thanks all.
Fastest 300
Re: Aluminum heads and spark plugs [Re: Crizila] #1583806
02/25/14 01:07 PM
02/25/14 01:07 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I've used anti-sieze on my heads for 30+ years but all I do is take a paper match or a small screwdriver, dip it and take one swipe down the threads. It doesn't take much as it will spread itself as you screw it in. I see guys caking it on and just shake my head.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Aluminum heads and spark plugs [Re: Challenger 1] #1583807
02/25/14 01:34 PM
02/25/14 01:34 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
That is one of the most over look things using aluminum heads and with a all aluminum engine it is a must.Its best to ground each head to the same place on the block and run a ground wire from there back to the -Neg on the battery.
As for the Anti-Seize I never use it on my Race engines as mentioned above they get changed often,but on Street-Cars that go 1000,000 miles I use just a small amount.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Aluminum heads and spark plugs [Re: MRMOPAR622] #1583808
02/25/14 02:22 PM
02/25/14 02:22 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Learning experience for me. At least I didn't blow anything up this time.
Fastest 300
Re: Aluminum heads and spark plugs [Re: MRMOPAR622] #1583809
02/25/14 03:04 PM
02/25/14 03:04 PM
fullmetaljacket Offline
Can't you just do as you say with grounding each head to the block and then grounding the block on both sides to the chassis instead of running a whole other cable to the negative side of the battery?
Learning curve here as well.
Me and electricity is like a kite and Ben Franklin. I guess he grounded himself as well back then. LOL.
Re: Aluminum heads and spark plugs [Re: fullmetaljacket] #1583810
02/25/14 06:41 PM
02/25/14 06:41 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Maybe I'm missing something but don't all those head bolts/studs do anything to ground it to the block??
But I can see where too much anti-seize on a plug would affect it's ground to the head.
Joe
Re: Aluminum heads and spark plugs [Re: fullmetaljacket] #1583811
02/25/14 08:04 PM
02/25/14 08:04 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
No MSD says thats not good enough,they say ground it to the -neg side of the battery only.
Re: Aluminum heads and spark plugs [Re: MRMOPAR622] #1583812
02/25/14 08:20 PM
02/25/14 08:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
In a frame car thats true... but on a chassis car
I just weld a 3/8 stud to each end of the chassis
for a ground lead.... on the frame car most of the
spot welds have corrosion in them so thats a weak
link
Re: Aluminum heads and spark plugs [Re: MR_P_BODY] #1583813
02/25/14 08:49 PM
02/25/14 08:49 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I do agree the chassis should be a good ground being you run your Neg off the battery to the chassis.I was having problems a few years back when I put my 1st all aluminum engine in my dragster and thought the chassis was good enough I even had my MSD ground bolted to it instead of the battery.But when I grounded each head to the same spot on the block as well as my MSD ground and run a ground cable to the Neg (which is ground to the chassis)like the MSD tech. said all my problems went away. I can grin about it now but when I was having problems,I did not think it was very funny and the tech. at MSD had a hard time making me believe it had to be that way.
PS I like to think that sometimes us Racers are just to smart for our own good....but I guess the Truth be told we are just to Hard-Headed to listen.
Re: Aluminum heads and spark plugs [Re: MRMOPAR622] #1583814
02/25/14 08:54 PM
02/25/14 08:54 PM
Chassis being a factory production chassis and frame being a tube frame as in fabricated car?
Page 1 of 3 1 2 3
