1968 Dart GTS master cylinder cap question
#1583260
02/24/14 01:28 PM
02/24/14 01:28 PM
Posts: 1,347 Wahoo Nebr
vette1986
Wahoo Nebr
Okay my Dad's 68 340 gts manual brake car is in need of a new cap for the master cylinder. I have seen two types on cars one has the screw in the center holding it down and then there is the one with the clip that flips up and over the cap to hold it. That is what his car has. Which is correct? Also who stocks these caps in the correct finish? I have checked the web and not had much luck on finding one. Thanks
1969.5 A12 Bee EV2 1971 Charger RT 1973 Duster tubbed 500 low deck 10.90 monster 3 440 polara vert projects
Re: 1968 Dart GTS master cylinder cap question
[Re: Rhinodart]
#1583262
02/24/14 01:49 PM
02/24/14 01:49 PM
Posts: 43,647 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Correct drum brake master...
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#1583263
02/24/14 01:50 PM
02/24/14 01:50 PM
Rhinodart
Rhinotruck
Rhinotruck
Aftermarket drum brake master...
A-Body's RULE!
[Re: Rhinodart]
#1583264
02/24/14 01:51 PM
02/24/14 01:51 PM
Rhinodart
Rhinotruck
Rhinotruck
71-up drum brake master...
A-Body's RULE!
[Re: Rhinodart]
#1583266
02/24/14 02:12 PM
02/24/14 02:12 PM
vette1986
Wahoo Nebr
It is a front disk car, any idea where to get the cover?
[Re: Rhinodart]
#1583269
02/24/14 05:52 PM
02/24/14 05:52 PM
vette1986
Wahoo Nebr
I had checked his site and I did not see any but I will call him. Yeah this dart has some odd things on it. early 68 car with the split grille insert, power steering, non power disk brakes, and it has headrests. I thought most 68's were non headrest?
[Re: vette1986]
#1583271
02/25/14 08:33 AM
02/25/14 08:33 AM
Posts: 1,923 Medina, Ohio
HEMICUDA
Medina, Ohio
We are the company that made the caps.
http://www.beaparts.com/item_detail.aspx?id=862
[Re: HEMICUDA]
#1583272
02/25/14 11:22 AM
02/25/14 11:22 AM
vette1986
Wahoo Nebr
I need the one without the screw in the center, the one that is held on by the flip up clip as it is disk brakes
