Dr D Stage 2 Front Disc Brake Kit
#1583192
02/24/14 11:01 AM
02/24/14 11:01 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
I am in the process of installing Dr D's Stage 2 front disc setup for my 70 Challenger (manual disc). I just wanted to let those know who may be in the market for a "kit", that the parts that are supplied by Dr D are very good quality and they bolt right in! I have currently installed the new spindles, my own lower ball joints, caliper mounting brackets, dust shields, the new combination valve, and the aluminum master cylinder (15/16" bore)/mounting kit. (Note: I am currently waiting on the rotors [RH threads] which should be here today).
The spindles and the mounting brackets bolted right in with no problems. I was assuming that this kit was going to come with an adjustable valve for the rear line, but to my surprise it came with a direct replacement valve that bolted in and all of the lines fit just like the valve that I removed. This is the first time that I have dealt with the new style aluminum MC that has the firewall mounting kit. This is the last time that I will be dealing with the four firewall bolts!! The only "issue" that I had were with the dust shields which were minimal and it appears that who ever is making these parts, people all over are having the same fitment issues. I read about the issues before I received the kit so I knew that ahead of time. A couple of tweaks to gain access around the knuckle mounting bolts, and they are on. So far with this kit, the shields are the only issue and it took a minute each to fix. The valve was the biggest surprise to me because I did not want to cut into my existing SS brake lines for an adjustable valve. The valve in the kit fit perfectly. The calipers are coated black and look great. I painted the spindles and the caliper mounting brackets just because they came bare and to keep the rust down in the future.
I just wanted to let the members know that Cass has put together a very nice disc brake kit. All of the small parts are separated into bags. All of the bolts, clips, hoses, bearings, brake shoes, calipers (slider type) and spindles are all new and included!
Once I get my rotors, I will able to start on the caliper assembly and I hope to have the kit wrapped up by the end of the week. It is still cold here so I am taking my time when the temps allow.
Thanks Cass!
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: Dr D Stage 2 Front Disc Brake Kit
[Re: YO7_A66]
#1583193
02/27/14 09:51 AM
02/27/14 09:51 AM
YO7_A66
Indiana
What is the torque spec for the "lock nut" on the end of the spindle that retains the bearing nut?
[Re: DoctorDiff]
#1583195
02/27/14 03:36 PM
02/27/14 03:36 PM
YO7_A66
Indiana
Got it, thanks.
(edit: I answered my own question when I got home and looked through my parts. No second locking nut)
Thanks Cass.
[Re: YO7_A66]
#1583196
02/28/14 02:54 PM
02/28/14 02:54 PM
YO7_A66
Indiana
I have been asked my some members to post some reference pictures from the kit. I am not done with the installation yet, but until then, I will post some pictures of the progress. The first picture is from another thread. I needed help with the orientation of these mounting tabs for the calipers.
[Re: YO7_A66]
#1583197
02/28/14 02:57 PM
02/28/14 02:57 PM
YO7_A66
Indiana
This is one of the minor mods that I had to do to get the splash shields on around the knuckle mounting nuts. Once again, this is due to the manufacturer not the vendor.(dimples around the large slot at bottom of picture. This gave the access around the knuckle arm mounting nut)
[Re: YO7_A66]
#1583199
02/28/14 03:05 PM
02/28/14 03:05 PM
YO7_A66
Indiana
This shows the new aluminum M/C with firewall adapter kit. Any future M/C changes will be made with only two mounting nuts. This one is the 15/16" unit for the manual disc setup. This was one of the M/C options by Dr D for a softer brake pedal. My existing pictures of the spindle assemblies are fairly dark. I will take better pictures this weekend.
[Re: YO7_A66]
#1583200
03/01/14 04:05 PM
03/01/14 04:05 PM
YO7_A66
Indiana
Hello everyone, I need a pointer on how to install the new brake lines to the calipers. I have four small washers and four larger washers. Were do they go?
[Re: DoctorDiff]
#1583202
03/01/14 04:18 PM
03/01/14 04:18 PM
YO7_A66
Indiana
I didn't think that you would be on the board today but I am glad you checked in! Thanks Cass!
[Re: YO7_A66]
#1583203
03/01/14 06:12 PM
03/01/14 06:12 PM
YO7_A66
Indiana
Is this the correct position?
[Re: YO7_A66]
#1583204
03/01/14 07:33 PM
03/01/14 07:33 PM
YO7_A66
Indiana
Dr D suggested that I test fit the bearings on the spindles before install in the case that there were any burrs on the bearing id's. I did find this issue, so I did as suggested and took some sandpaper and just cleaned the id of the bearings and they slid right on. One of the spindles had a burr on the keyway but some sand paper took care of that too. Thanks again Cass for the suggestion.
Note: Dust shield orientation incorrect.
[Re: DoctorDiff]
#1583207
03/01/14 07:45 PM
03/01/14 07:45 PM
YO7_A66
Indiana
That picture is hard to tell but that is the drivers side and the opening in the shield is under the caliper mounting bracket.
[Re: YO7_A66]
#1583210
03/02/14 05:17 PM
03/02/14 05:17 PM
YO7_A66
Indiana
I got the dust shields swapped.
Thanks Cass.
[Re: YO7_A66]
#1583211
03/02/14 11:58 PM
03/02/14 11:58 PM
YO7_A66
Indiana
Cass, Do the new rotors come with bearing races installed?
If so, do I use them or knock them out and use the races that came with the bearings that were provided in the kit?
Thanks again.
