68 road runner hood release bolts #1582602
02/22/14 10:49 PM
02/22/14 10:49 PM
Avondale AZ
Prodart440 Offline OP
Avondale AZ
I am putting my car back together and cannot find the bolts that hold the hood latch release lever on (the part that sticks thru the grill). Anyone have pictures of them so I know what I am looking for??? Thanks!!!
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: 68 road runner hood release bolts [Re: Prodart440] #1582603
02/23/14 01:15 AM
02/23/14 01:15 AM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
My 69 Roadrunner doesn't have a hood latch but I think there are two silver Phillips screws that hold the hood latch down to the grill support?
Re: 68 road runner hood release bolts [Re: Prodart440] #1582604
02/23/14 10:53 AM
02/23/14 10:53 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
These screws? Not sure if the finish is correct.
Re: 68 road runner hood release bolts [Re: 68jim] #1582605
02/24/14 01:42 AM
02/24/14 01:42 AM
Avondale AZ
Avondale AZ
Those are the screws!! Any pictures of them off the car?? How long and what size are they??
Aaron
68 Coronet 440
Re: 68 road runner hood release bolts [Re: Prodart440] #1582606
02/24/14 01:55 AM
02/24/14 01:55 AM
Warrenton, VA
Warrenton, VA
Finish should be silver and hood spring is black phosphate
Re: 68 road runner hood release bolts [Re: Prodart440] #1582607
02/24/14 12:45 PM
02/24/14 12:45 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Pretty easy to determine the lenght if no one comes up with it. A steel bolt/screw into a steel thread is 1 to 1 minimum. So if the diameter of the bolt/screw is 1/4" then you'll need a minmum of 1/4" of thread engagement. Measure through the hood release to the start of the threads then an the diameter of the screw/bolt.
