OEM tire pressure monitor system .... #1582142
02/21/14 08:36 PM
02/21/14 08:36 PM
Florida STAYcation
dOc ! Offline OP
The village idiot's idiot
dOc !  Offline OP
Florida STAYcation
.... aNyOnE know the ins-and-outs of this? ... my tire pressure is good ... but the OH console says they need attention. Faulty sensors ? ... best just to broom-it-all away ?
Re: OEM tire pressure monitor system .... [Re: dOc !] #1582143
02/21/14 09:07 PM
02/21/14 09:07 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
First what kind of car is it ?
Second have it scanned to see if it has any codes in it. Ron
Re: OEM tire pressure monitor system .... [Re: dOc !] #1582144
02/21/14 09:09 PM
02/21/14 09:09 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
if the pressure is good then its a bad sensor..did you do any tire work lately?..adjust the air pressure?..if you adjusted the air the car needs to be driven awhile to clear it..
Re: OEM tire pressure monitor system .... [Re: AARCONV] #1582145
02/22/14 10:14 AM
02/22/14 10:14 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
did you check all FIVE tires? or just the 4 easy ones?
**Photobucket sucks**
Re: OEM tire pressure monitor system .... [Re: 70Cuda383] #1582146
02/22/14 12:09 PM
02/22/14 12:09 PM
Ohio
john55 Offline
john55  Offline
Ohio
yep, some do have sensors on the spare
The Plymouth Win You Over Beat Goes On
Re: OEM tire pressure monitor system .... [Re: john55] #1582147
02/24/14 01:11 AM
02/24/14 01:11 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Yes what kind of car would help. You may be able to "learn the sensors" with your OC If it's a option you'll need a good magnet to do it.
Re: OEM tire pressure monitor system .... [Re: dOc !] #1582148
02/24/14 11:12 AM
02/24/14 11:12 AM
Stinnett, Tx
rumblebee4232 Offline
Stinnett, Tx
if your pressure is too high it will turn the light on too.. I had a 2011 ram 2500 that I pulled my gooseneck with.. the first time i hooked it up I added pressure to the tires due to the increased weight and truck went to heavy load mode.. a couple days after I unhooked the trailer the tire pressure light came on checked all the pressures were above the minimum sensor pressure and below the maximum tire pressure on the side wall but they were above the maximum that was programmed in the computer for an unloaded truck,, found that out after i took it to the dealer for the light..
