P Body i will do that ! I discoverd that they made marks on the pick up plate before the took it apart and lockt the plates together and they dident get it strait up so i did that first and that almost made it line up to the brass
Im simply trying to tell what you could get so look at it before you install your distributers
I also dident like the end play on the reluctor shaft as it whas to large travel so i took of a locking washer under the screw that holds the reluctor unit together whit the shaft that run threw the body of the distributer down to the drive gear in the block !
