Which Station Wagons can haul a 4x8 sheet of plywood? #1581950
02/21/14 11:24 AM
02/21/14 11:24 AM
Cruising!
Q
QuickDodge Offline OP
Q
Cruising!
Which Mopar station wagons can haul a sheet of plywood inside with the tail gate closed. Will the front seat have to be moved forward for it to fit?
Edit: I'm primarily interested in 1965 and older models.
Re: Which Station Wagons can haul a 4x8 sheet of plywood? [Re: QuickDodge] #1581951
02/21/14 11:29 AM
02/21/14 11:29 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
This one will !!
Re: Which Station Wagons can haul a 4x8 sheet of plywood? [Re: 62maxwgn] #1581952
02/21/14 11:32 AM
02/21/14 11:32 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Now you know.
Re: Which Station Wagons can haul a 4x8 sheet of plywood? [Re: 62maxwgn] #1581953
02/21/14 11:32 AM
02/21/14 11:32 AM
Cruising!
Q
Q
Cruising!
What is that car? A 1963 B body?
Edit: I replied before you posted the second picture. Thanks for the pics!
Re: Which Station Wagons can haul a 4x8 sheet of plywood? [Re: QuickDodge] #1581954
02/21/14 04:07 PM
02/21/14 04:07 PM
League City, TX
BlueGhost Offline
BlueGhost  Offline
League City, TX
I'm fairly certain my 58 Plymouth Suburban will, the second row seat might have to be folded forward.
I think my 06 Magnum would also with the second row seat folded. I fit a 4x6 show door back there one.
1958 Plymouth Suburban
Re: Which Station Wagons can haul a 4x8 sheet of plywood? [Re: QuickDodge] #1581955
02/21/14 07:15 PM
02/21/14 07:15 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
just for hauling plywood?kind of an odd question.get a truck
Re: Which Station Wagons can haul a 4x8 sheet of plywood? [Re: mcmopars] #1581956
02/21/14 08:09 PM
02/21/14 08:09 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Re: Which Station Wagons can haul a 4x8 sheet of plywood? [Re: QuickDodge] #1581957
02/22/14 12:02 AM
02/22/14 12:02 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
You don't need a wagon or a truck.
Re: Which Station Wagons can haul a 4x8 sheet of plywood? [Re: QuickDodge] #1581958
02/22/14 05:02 PM
02/22/14 05:02 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
As I recall, that was a selling point in the literature for my mom's old 1970 Plymouth station wagon and for my seven passenger Dodge Caravan. In both, the front seats had to be moved up a bit for it to fit with the tailgates shut.
I hauled plywood and masonite paneling in both.
Craig
Re: Which Station Wagons can haul a 4x8 sheet of plywood? [Re: QuickDodge] #1581959
02/23/14 09:26 AM
02/23/14 09:26 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Wait. Let's go back to square 1.
You want to buy a pre-65 to use for Home Depot runs?
