Re: Torsion bar won't go back in!!!!
[Re: 70satelliteguy]
#1581942
02/21/14 12:28 PM
02/21/14 12:28 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
If the hex isnt lining up you need to push the lower arm down.I usually take the upper ball joint off then install the bars.They have to be under a slight load on install or the car will sit low and not adjust up.Rocky
Chrysler Firepower
#1581946
02/21/14 01:26 PM
02/21/14 01:26 PM
RapidRobert
I'd have the tire off as you need the assy you're working on as light & easy to work with as possible. Jack stands under the subframes at a decent height. Have the LCA pretty much out horizontle & put a floor jack under it in the center so you can manipulate its' height slightly as needed. I'd have the square block (the one that the adjust bolt goes thru) out of the D window then with a tire iron lever the nub up till the T bar hex lines up so you can insert the tbar. Then lever the blade that's inside the D window as needed so you can get the block back in there laying correctly as it has notches on the bottom to sit on there flat
#1581948
02/21/14 03:54 PM
02/21/14 03:54 PM
Posts: 85 Rio Linda, CA
nytemuvr
Rio Linda, CA
Jack the car in a different place as the frame distorts when it's on jacks and stands, check the door alignment when it's jacked up. The frame bends a bit, throws things off. If your talking torsion bars and not the a-arm struts as someone mentioned cotter keys. Torsion bars don't have cotter keys, the struts don't use cotter keys either, they use rolled pins on the front end of the struts. Is the round wire ring that holds the torsion bar in the frame still in the hole?
1972 Challenger 340(original owner)
1968 D100
1997 HD Road King
