really dumb MSD/ tach wiring q.. #1581934
02/21/14 11:59 AM
02/21/14 11:59 AM
jax. fla.
70Dustmite440 Offline OP
jax. fla.
I have looked and haven't found a good answer. MSD digital 6 plus box with msd dist, autometer tach. does the tach pickup hook to the coil or the box?
on a side note I did see its saying not to hook the power wire from the box to the alternator, looks like that's how I had it before on the car but maybe I should move it?
Thanks! Eric.
8sec. street car, been there done that. Quitting when your ahead isn't the same as quitting.
[img]https://scontent-atl.xx.fbcdn.net/hphoto...amp;oe=55DB3E4C[/img]
https://www.facebook.com/eric.norton.1048
R.I.P.UN.
Re: really dumb MSD/ tach wiring q.. [Re: 70Dustmite440] #1581935
02/21/14 12:03 PM
02/21/14 12:03 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Box
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: really dumb MSD/ tach wiring q.. [Re: Adobedude] #1581936
02/21/14 12:14 PM
02/21/14 12:14 PM
jax. fla.
jax. fla.
Re: really dumb MSD/ tach wiring q.. [Re: 70Dustmite440] #1581937
02/21/14 12:30 PM
02/21/14 12:30 PM
an8sec70cuda Offline
Hook the tach up to the MSD box.
The MSD's power wire should go directly to the positive battery terminal. I hooked mine to the big post on the starter relay.
MSD's are sensitive to low voltage...that's why they say to hook it directly to the battery.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: really dumb MSD/ tach wiring q.. [Re: 70Dustmite440] #1581938
02/21/14 12:33 PM
02/21/14 12:33 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
Eric,
You will hook the tach lead to the box. The car won't run if you try to hook it to the coil and you may kill the tach.
They tell you not to hook to the alternator because you can get fluctuation in voltage and also get some signal interference from the alternator that will mess with the box. Make sure you pull straight off of a battery source like the starter solenoid and be very sure you have the best ground possible. The digital boxes are very sensitive an a questionable ground can cause many headaches. Seen it way too many times.
Jason
BJS racing
Back in the swing of things at Painless again! Great to be back!
Re: really dumb MSD/ tach wiring q.. [Re: an8sec70cuda] #1581939
02/21/14 12:34 PM
02/21/14 12:34 PM
jax. fla.
jax. fla.
Gotcha, thanks! Funny the wire is 'missing' but there has been several weird things I've found so far
Re: really dumb MSD/ tach wiring q.. [Re: 70Dustmite440] #1581940
02/21/14 12:42 PM
02/21/14 12:42 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
If you look on the side of the box there is a spot for a female spade terminal to plug into the box (on some of them). That is the tach out put. If you give me the number of the box you are using I can tell you exactly which wire or where to hook the tach lead to.
