Does anyone make a composite intermidiate gear? #1581805
02/21/14 12:25 AM
02/21/14 12:25 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
I know they make a polycarbonate gear for the brand x cars. Do they make anything like that for a big block Chrysler?
If my options are still bronze or the new coated gear does anyone have any experience with the coated gear?
I treed to get a billet roller cam with a pressed on cast gear but that is not an option for Chrysler stuff.
Re: Does anyone make a composite intermidiate gear? [Re: Jeremiah] #1581806
02/21/14 04:21 PM
02/21/14 04:21 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I don't believe the composite gears are available for any Mopar applications.
I looked into the coated gears and decided to try out a bronze gear and be very careful to limit the distributor shaft vertical play using a slip-on (screw-type) collar on the shaft. Can't tell you how that's working out, yet, though.
The coated gears have warnings against using them w/ high oil pressure, same as the composite gears. I've been cranking 60-65 psi hot and don't want to find out the hard way what their true limit is for handling that sort of load on the gear.
Re: Does anyone make a composite intermidiate gear? [Re: BradH] #1581807
02/21/14 04:42 PM
02/21/14 04:42 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Well I went ahead and ordered a coated gear and hardened shaft from Kevin at Hughes this morning along with a stack of Superformance gaskets. I don't mind being the guinea pig for some of this new stuff. When my car hits the street we will have some empirical data. Thanks for the feedback Brad!
Re: Does anyone make a composite intermidiate gear? [Re: Jeremiah] #1581808
02/21/14 07:31 PM
02/21/14 07:31 PM
Toronto
mshred Offline
mshred  Offline
Toronto
I made a post about this last week I think....not many replies, but they do make them for mopars, although they say NOT to use them with HV pumps
Re: Does anyone make a composite intermidiate gear? [Re: mshred] #1581809
02/21/14 09:08 PM
02/21/14 09:08 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Are you speaking of the coated gear or the elusive composite?
I think I have two of each style of pump so that is not a huge deal. I will also give Hughes a call and see what they know.
Re: Does anyone make a composite intermidiate gear? [Re: Jeremiah] #1581810
02/21/14 10:23 PM
02/21/14 10:23 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Good question lol...All I know is its a crane gear, and now that I am thinking about it, maybe it is just coated. I will call hughes tomorrow as well and see if they have one of these composite gears for small blocks...might be the ticket for the HV pump and the roller cam- for a street car, having a gear that doesn't wear itself in to the engine oil would be nice
Re: Does anyone make a composite intermidiate gear? [Re: mshred] #1581811
02/21/14 10:58 PM
02/21/14 10:58 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Re: Does anyone make a composite intermidiate gear? [Re: Jeremiah] #1581812
02/22/14 03:20 AM
02/22/14 03:20 AM
Toronto
mshred Offline
mshred  Offline
Toronto
Hughes sells the coated gear.
I will have to see if it is compatible with an HV pump..they don't warn against it, so maybe it is?
Re: Does anyone make a composite intermidiate gear? [Re: mshred] #1581813
02/22/14 02:57 PM
02/22/14 02:57 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Let me know what they say when you talk to them.
Re: Does anyone make a composite intermidiate gear? [Re: Jeremiah] #1581814
02/22/14 05:58 PM
02/22/14 05:58 PM
Toronto
mshred Offline
mshred  Offline
Toronto
I wasn't able to speak to them (called a couple times and no answer), but from some research I have done, it seems to be the exact same gear as the crane gear but marketed as theirs- as in coated (atleast for SB). Crane says to not use coated gears with used camshafts as it will not wear the teeth in properly and can damage the gear...they also caution against using it with an HV pump, whether the shaft is hardened or not, as the stress from the HV pump will wear it out ( I read of one story on the bullet that scared me away from the composite/coated gear and HV pumps).
I ended up with a Milodon bronze gear and hardened shaft setup from Summit (I had a 10% off coupon that I used). Sorry if I wasn't much help- I would have tried the coated gear if my cam was brand new, but it is used (and appears to be pretty old at that) and I am running an HV pump. Would rather not take any chances.
If you talk to them, let us know what they tell you.
Re: Does anyone make a composite intermidiate gear? [Re: mshred] #1581815
02/22/14 06:08 PM
02/22/14 06:08 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
I think they are at the big expo show at Pheasant Run this weekend. I'll hit them up on Monday and see what the deal is with running a HV pump. I can't imagine it would be that much more force to drive a HV pump over the standard volume unit. If I remember right the HV's are designed to pump 25% more volume. Edit: I checked the Melling website and the HV spec is 25%.
Re: Does anyone make a composite intermidiate gear? [Re: Jeremiah] #1581816
02/22/14 06:37 PM
02/22/14 06:37 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Here is the flyer from Crane.
Re: Does anyone make a composite intermidiate gear? [Re: Jeremiah] #1581817
02/23/14 01:34 AM
02/23/14 01:34 AM
Is melonized(SP?) steel a new word for composite materials? I seem to remember that you can use a steel gear, not iron, on a steel billet cam with no problems I had a customer do that years ago on a street steel hydraulic roller cam for a 302 Ford, Comp Cams change the firing order on that cam to the Windsor firing order There where some other problems do to his inexperience on steel camshaft cores, he ate two of the stock distributor gears before buying the correct steel one
Re: Does anyone make a composite intermidiate gear? [Re: Jeremiah] #1581818
02/23/14 01:54 AM
02/23/14 01:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
How often are you guys going through the bronze gears..
so far I never have.. the one in my 395 engine has
about 900 passes on it and it has minimal wear.. I
thought about using it in my 416 in the Rampage(street
car) but I found a new one in my stash of junk... it
better last a FEW thousand miles
Re: Does anyone make a composite intermidiate gear? [Re: Jeremiah] #1581819
02/23/14 02:28 PM
02/23/14 02:28 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Here is some interesting information on selection and set up.
http://www.stangtv.com/tech-stories/elec...ut-the-details/
Getting old just means you were smarter than some and luckier than others.
Re: Does anyone make a composite intermidiate gear? [Re: Cab_Burge] #1581820
02/23/14 02:49 PM
02/23/14 02:49 PM
BradH Offline
BradH  Offline
No. The composite gears are different, "non-metallic" IIRC.
I had a conversation w/ Dwayne Porter on the idea of trying one of the new Crane melonized gears. We came to the conclusion that if I did encounter some wear issues due to oil pressure load on the shaft or whatever, that the resulting particulate that comes from a bronze gear would probably do less damage than what would come off some type of treated steel gear.
End decision was to run a bronze gear, but (as I noted above) be careful during set-up to minimize vertical play of the gear. Can't add anything else now since my junk's still not running again.
Re: Does anyone make a composite intermidiate gear? [Re: BradH] #1581821
02/23/14 03:06 PM
02/23/14 03:06 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
I am just thinking out loud here but why not run the brass gear for a little bit to run it in. Then remove it and have it cryogenic treated or some other process that would make it last longer.
Re: Does anyone make a composite intermidiate gear? [Re: dannysbee] #1581822
02/23/14 03:40 PM
02/23/14 03:40 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
That is good thinking. I am going to give the steel gear a go. If anything I always have an identical spare short block.
Re: Does anyone make a composite intermidiate gear? [Re: Jeremiah] #1581823
02/23/14 04:22 PM
02/23/14 04:22 PM
My 518 pump gas motor had a new bronze gear put in it when I assembled it in 2004 the first time, it had the same gear in it with no noticeable wear when I sold it last year
Re: Does anyone make a composite intermidiate gear? [Re: Cab_Burge] #1581824
02/23/14 05:08 PM
02/23/14 05:08 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
My 518 pump gas motor had a new gear put in it when I assembled it in 224 the first time, it had the same gear in it with no noticeable wear when I sold it last year
That is good to know Cab. I guess if the coated steel gear doesn't work out I'll shoot for the bronze unit on "take 2".
