Re: steering column ?s
[Re: ffej]
#1581687
02/20/14 09:22 PM
02/20/14 09:22 PM
RapidRobert
(1) I believe you'd have to drill it out. I'm assuming it is extremely worn & needs to be replaced tho I have not run into that (yet). (2) Take off the st wheel & a bit more as needed till you can see the cyl mechanism & I believe there is a pin you need to depress so the cyl can come out with the key in it
[Re: ffej]
#1581689
02/20/14 10:36 PM
02/20/14 10:36 PM
RapidRobert
be carefull as to not nick the surrounding material while drilling it out which could cause a stress riser that could crack the shaft over time as the shaft is under constant compression/tension while you are driving. After you get it out I'd slightly heat the shaft & freeze the new pin so it'll slip in easy & as you know get it exactly centered immediately. Are you sure it needs to come out? Use a drill press & have a helper hold the steering wheel end horizontle while you do the drilling starting with a small bit & use a rag wrapped t protect it so as to not make any nicks/scratches on the end you're working on
[Re: buildanother]
#1581692
02/20/14 10:55 PM
02/20/14 10:55 PM
Challenger 1
Cincinnati, Ohio
I've always been able to drive those solid pins out, whether using hammer and drift punch, combination of small sockets combined with decent bench vice etc.
Me too.
