1968 Inland Shifter question.
#1581579
02/20/14 11:50 AM
02/20/14 11:50 AM
Posts: 2,151 Bristol, CT
RalphsRapidTrnst
Bristol, CT
Hi guys need help regarding the inland shifter. What was the cut off build date for the change over from an inland to the hurst handle? I was told around Nov 30, 1967.
Re: 1968 Inland Shifter question.
[Re: Rhinodart]
#1581581
02/20/14 04:18 PM
02/20/14 04:18 PM
Posts: 704 USA
rftroy
USA
Well, this is news that could make me happy.
My 383 Barracuda has a C20 on the fender tag, which would be Dec. 20 1967. But, I also have the MSO for the car, which has a transfer date from Chrysler to the dealer of 12/16/1967. Car first registered on 1/2/1968; nice Christmas present.
The car had no trans or shifter when I bought it, so, would I be justified in putting a Hurst shifter in it?
Robert
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
[Re: azmopar]
#1581584
02/20/14 04:32 PM
02/20/14 04:32 PM
Posts: 1,603 Central Ohio
BMChrysler68
Smarter than the average bear? I think not.
Central Ohio
I wouldn't fault you either, AZ. Put that thing on a shelf until you're ready to sell it. Unless it's to me, in which case, you can keep it.
1968 Plymouth Fury III 2dr FT, 383-4v, 4 speed
1972 AMC Ambassador SST wagon 360-4v, automatic
2014 Challenger R/T Classic 6-speed
[Re: BMChrysler68]
#1581585
02/20/14 04:33 PM
02/20/14 04:33 PM
Posts: 704 USA
rftroy
USA
Somewhere (but it was over 20 years ago) I got the idea that it was a Jan. 1 change. I was going to get one of Brewer's Hurst shifters with the bracket for the Inland handle. This will save lots of money.
[Re: 6bblgt]
#1581589
02/20/14 07:59 PM
02/20/14 07:59 PM
RalphsRapidTrnst
Bristol, CT
HURST shifted cars have a "REVERSE" light on the dash, INLAND cars DO NOT. So, an original dash would tell the "truth". Those with Dec. '67 & Jan. '68 cars should share what they find.
Really is this true? Can this be verified? My understandig is the dash reverse light came out in 69. That would make if easy. B-body is what I am loking at.
[Re: RalphsRapidTrnst]
#1581591
02/20/14 08:11 PM
02/20/14 08:11 PM
Posts: 704 USA
rftroy
USA
Oh, yeah. I forgot about that. I'm sure I knew that at one time, since I was so sure the car originally came with an Inland.
The Inland had a reverse lockout mechanism, whereas the Hurst only had a spring to keep you out of reverse. The light was to warn you if you put it in the wrong gear.
Double checked mine. Original dash with no hole for reverse light. Bummer. Looks like I'll be getting a Brewer's conversion shifter after all.
Dec. 20, 1967, C20, on fender tag.
Robert
[Re: 6bblgt]
#1581594
02/20/14 08:18 PM
02/20/14 08:18 PM
RalphsRapidTrnst
Bristol, CT
The "REVERSE" light came out for the HURST shifters, INLANDs didn't need it due to the reverse lock-out "T" pull handle linkage.
So you're all agreeing. 1968 was the first year for the reverse light if it had a Hurst Shifter. No Reverse light means inland.
[Re: 6bblgt]
#1581595
02/20/14 08:19 PM
02/20/14 08:19 PM
RalphsRapidTrnst
Bristol, CT
Another "close, but not quite" - June '68 hardtop Road Runner, missing the bench seat interior and found a console & related parts. ..... but "I spy!" a "REVERSE" light.
I do to. BUT I spy a console and no RR came with a console in 68. Need a better example. ![](/ubbthreads/images/graemlins/popcrn.gif)
