adding leafs #1581434
02/19/14 09:34 PM
02/19/14 09:34 PM
Iowa
76dodgeboy Offline OP
Iowa
I have a truck that has all but the main leaf broke. Do I just pull the pin/bolt from the center and be able to swap them out? I really don't want to mess will pulling the main leafs to replace the pack. Thanks
Re: adding leafs [Re: 76dodgeboy] #1581435
02/19/14 10:50 PM
02/19/14 10:50 PM
put a pair of C clamps about half of the distance of the length of the lower leaf on each side pretty much equidistant out from the center bolt to keep the pack compressed then remove the nut. If it's tight I'd crack it with a nut cracker then remove it rather than breaking that special bolt with the round head. Unscrew the clamps evenly to release the old leafs then add/replace the new leafs & compress em with the C clamps so you can reinstall a new nut on the center bolt
Re: adding leafs [Re: RapidRobert] #1581436
02/19/14 10:58 PM
02/19/14 10:58 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Just jack it up, pull out the bad leaves, wedge a section of 2x4 between the overload spring, and the main leaf, wire it all together, paint it black, and toss a little dust on it before the paint dries.
Truck is ready to go!
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
