Re: turbo carbon seal.HELP!
[Re: Clanton]
#1580885
02/19/14 12:25 PM
02/19/14 12:25 PM
Posts: 13,492 Marion, South Carolina [><]
an8sec70cuda
I can't drive my car like it is on the street and I am looking at that more all the time.
Why not?
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: Clanton]
#1580887
02/19/14 02:30 PM
02/19/14 02:30 PM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
The obstruction sticking out of the hood!Laws against it.
When you take that obstruction off, let me know, I'll take it to the junk yard for you.
[Re: Clanton]
#1580889
02/19/14 03:58 PM
02/19/14 03:58 PM
Posts: 928 NC
SLOW67
NC
I just talked to turbonetics and the largest turbo I can get is a to4E 60 for 800hp max falling short of my 1,000 to 1200 hp goal.
Switch to blowthru and problem solved
[Re: FastmOp]
#1580892
02/19/14 05:35 PM
02/19/14 05:35 PM
Posts: 4,492 northern,Ohio,USA
Clanton
northern,Ohio,USA
Get two turbos for a hot air turbo Buick. 1981 were hot air cars. I think some of the late 70's trans AMs were hot air as well.
You want to make big power but will never make it with your approach. You could do a single 88 and blow thru and accomplish your goals. You know how to make headers now and you ain't scared to spend the $$. I would think you would want the HP without the hassle.
i don't have to make big power but ya gotta start somewhere.You must understand that my goal is for a draw thru not a blow thru good bad or other I am finding what the limits are and go from there.
[Re: Clanton]
#1580895
02/20/14 02:16 AM
02/20/14 02:16 AM
Posts: 928 NC
SLOW67
NC
I guess a Chevrolet guy might ask the same thing,Why a MOPAR?
To each his own...good luck with it
[Re: Clanton]
#1580896
02/20/14 02:22 AM
02/20/14 02:22 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
You are obviously set on a draw thru. Just get the biggest offerings and live with what you end up with. Looks seem more important than function here anyway. If you like the look of a draw thru system, then you need to be prepared for all the down sides that go with it. The less than stellar all out performance goes hand in hand with very poor cold start, laggy spool up, poor cyl to cyl distribution, detonation, explosive boost tubes, etc... I've gone this route, and believe me, it aint worth the hassle if power is what you're after. For cruise nights or whatever it looks kinda cool, but than you have to come up with a long list of excuses to tell the guys that want to race you.
